Unread 01-14-2019, 05:03 PM   #1
Olivrae
Yet another subfloor question
Hi, new to the list. trying to get some advice on my floor.
In the planning stages of a 2nd flr master bath with only studs and rough plumbing currently. The subfloor(3/4" T&G) sits on a 15' span made up of 2x10 12"OC. The deflecto tells me I'm L386. I'd like to add additional underlayment for some breathing room.
I can't find a calculator for how much I can improve the stiffness (glueing, screwing and offsetting edges) by adding another layer of plywood.
Any insight would be appreciated and look forward to the help I'm sure to get here. Thanks!
Olivrae is offline   Reply With Quote
Unread 01-14-2019, 06:30 PM   #2
Welcome to the forum, Dan.
The Deflecto calulator calculates the joist structure only (which you're reporting at L/386). Adding plywood layers to the top doesn't increase this structural value. If you want the structural value to go up, you need to use more joist material (or add plywood to the underside of the joists using specialized, and rarely used techniques). I plugged in your figures into the Deflecto and am coming up with a different calculation. I must be using different values or wood species or spacing or span than you, so....
1) Can you clarify which values you're using for the Deflecto, and
2) I'll ask if there's anything specific you're concerned about, and
3) Can I confirm that you're planning to use man-made ceramic/porcelain tiles, and
4) Can I ask which tiling method you're planning to use?
Unread 01-14-2019, 07:33 PM   #3
muskymike
muskymike's Avatar
Hi Dan welcome. I agree with Bubba. I ran your measurements through the Deflecto and come up with 424 which it good for ceramic or porcelain. Adding more subfloor doesn't add strength to the joists.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 01-14-2019, 08:01 PM   #4
Olivrae
Thanks for the replies.
To be more specific the span is 15'6".
I plan to use a porcelain tile over Ditra. Not sure on the tile size since I'm assuming the smaller the better if the floor deflects a bit. wondering if 12x12 are too large.
Unread 01-14-2019, 08:11 PM   #5
Welcome, Dan.
First, do you actually know that your joists are Douglas Fir or Southern Yellow Pine and are of good grade? If not, your calculations might be much better than your joist structure.
Second, the size of your tiles has nothing at all to do with the floor deflection requirement. What will matter a great deal is the flatness of your floor, especially if you select a large format tile.
Unread 01-15-2019, 09:58 AM   #6
Olivrae
They are No. 2 SYP in good shape. The joists have 1x3 strapping 12"OC. It's 20yo construction.
Unread 07-25-2021, 09:54 PM   #7
Olivrae
partition wall question
Hi all,
I have a 2nd floor space roughed in for a Bath (14 x 11) that sits on top of a 1st floor room with a clear span of 15.5.
The joists (2x10 spf no2, 12in OC) run in the long dimension.
The Deflectolator gives me a L/364 result.
additional info is that the bathroom floor is 3/4 TG ply glued/nailed and there is strapping nailed to joists to support the ceiling sheetrock for the room below. the floor feels solid but I'm concerned about cracking tile.
My question is this:
The bath partition wall at 11' is not load bearing but does it provide any stiffness to the floor?
Thanks in advance.
Unread 07-25-2021, 10:01 PM   #8
Olivrae
blocking
I should have mentioned that I did add some blocking in 4 of the joists cavities where the shower sits since I had the floor opened anyway for plumbing work. After some research it seems this won't add much in the way of stiffness.
Unread 07-26-2021, 01:52 AM   #9
Hi, Dan.
To get L/364, you used 10.0” for the height of the joists. If that’s what you’ve actually got, you’re good to go. But if your 2x10 joists are actually 9.25” like most of them are, that brings your rating down to L/298.
You are correct that blocking doesn’t add any stiffness to the length of your joists.
About this partition...are you referring to the partition within that 2nd floor bathroom, or are you referring to the room below?
Unread 07-26-2021, 07:35 AM   #10
Welcome back, Dan.
I've combined your original thread on this floor here.
Would help if you'd add a geographic location to your User Profile, but even for Southern SPF I can find a span table that indicates your joists met building code (L/360) when the structure was built, which is what the ceramic tile industry requires for a ceramic tile installation. Our Deflectometer is more conservative and we think a better indicator for older structures, but it's up to you what you're willing to tile over.
I have the same question as does Goldstein about your party wall.
Another subfloor question MGJ Tile Forum/Advice Board 26 03-26-2014 05:19 PM
Another subfloor question Alex S Tile Forum/Advice Board 3 01-27-2008 12:53 PM
And yet, another subfloor question kiefer Tile Forum/Advice Board 4 12-18-2002 07:49 AM
