Unread 07-25-2021, 04:44 PM   #1
Don Monfils
Pro Carpet
Don Monfils's Avatar
Stone backsplash grout clean up
I did a stone backsplash this week.
I used this 511 impregnator / sealer the night before I grouted.
I applied it with a microfiber cloth, let it set for 5 minutes and wiped off any excess with a clean towel. The next day I went back to grout using Custom from Home Depot. The grout removal was very difficult. I spent a ton of time and got it fairly clean. I’m hoping I can go back with a grout haze remover and maybe a white abrasive pad?? please advise me if this makes sense, or of a better plan.
Also after cleaning the grout I noticed the finish on the edge trim is discolored.
I’m guessing this is probably from the sealer?????????*?? I realize I should have tapes them off prior to sealing. Is there anything that can be done to remedy this ?
Thanks in advance for your time, Don Monfils
Don
Don Monfils is offline   Reply With Quote
Unread 07-26-2021, 10:23 AM   #2
Hi Don,
It looks like you used black grout or a very dark gray (charcoal). I gave up using black grout early on in my career. It stains everything it touches.
Also, the type of tile/stone you used in not easy to grout. You have to smear small areas and clean them completely as you go. Is there a way you can tell us what type of stone you used? It'll make a difference in what you might use to improve the look.
Unread 07-26-2021, 05:34 PM   #3
Don Monfils
Pro Carpet
Thanks for the response , not sure what type of stone it is.
Customer bought it from Home Depot.
Could the grout have stained the schulter edging?
Don
Unread 07-30-2021, 07:47 AM   #4
Hi, Don.
Do you have a closer pic of the Schluter edge that’s discolored?
Unread 07-31-2021, 07:15 AM   #5
Also, which Custom grout did you use? Polyblend sanded, unsanded, Prism, Fusion?
Did you use the plastic Schuter trim?
Unread 07-31-2021, 11:31 AM   #6
Don Monfils
Pro Carpet
No better pic , sorry
Pollyblend plus in sanded grout
I’m going back Tuesday ,I’ve been super busy hopefully someone could give me some advice
Don
Unread 08-01-2021, 11:03 AM   #7
Don, Black grout?
If the tile is not marble or slate you can use a mild acid to clean it. What kind of Schluter trim? If metal you can't use acid. I don't know what else to tell you.
Unread 08-01-2021, 02:46 PM   #8
Don Monfils
Pro Carpet
Grout is coffee bean, dark drown
Trim is metal brushed nickel? Kind of looks like chrome.
Don
Unread 08-02-2021, 09:06 AM   #9
Well, in the picture the grout job looks pretty good to me. You can't get the grout out of the depressions. It's part of the look. Try a little white vinegar mixed 50/50 with water in an out of the way spot on the trim. Better yet, if you have a scrap of the trim, test it there. Stronger acids will turn the metal dark in a heartbeat.
Unread 08-02-2021, 05:19 PM   #10
Don Monfils
Pro Carpet
Thanks John, I will try that
Don
Applying grout to a natural stone backsplash mikemyers Tile Forum/Advice Board 19 05-10-2016 10:10 AM
Dried grout on stone on mixed mosaic backsplash josiel Cleaning, Restoration and Sealing 9 02-02-2014 11:24 PM
Mosaic Stone (no grout) with Mastic for backsplash? kezug Tile Forum/Advice Board 21 04-16-2013 08:14 PM
HELP! with stacked stone backsplash and grout shad0w Tile Forum/Advice Board 16 07-19-2010 04:39 AM
How do you clean a brick stone fireplace? Lystra Cleaning, Restoration and Sealing 1 09-27-2006 04:11 AM
