Unread 07-20-2021, 01:36 PM   #1
thedudemn
Remove hardi board or not
So I'm re-tiling a small bathroom. I removed the tile by breaking the tile with a hammer. The underlayment is 1/2 hardi board. Do you guys remove it and install new underlayment or do you try to remove the thinset and patch any damage where the hardi board was damaged with some layers still attached to the removed tile.
Hue
thedudemn is offline   Reply With Quote
Unread 07-20-2021, 02:51 PM   #2
Welcome back, Hue.
This in a shower wet area or outside the wet area?
Unread 07-20-2021, 03:48 PM   #3
thedudemn
Sorry, I should have made that clear. The dry area not the shower pan.
Hue
Unread 07-20-2021, 04:27 PM   #4
You can probably get away with patching the substrate, but I would always find it far more expedient to remove the wallboard, tile and all, to begin with and start over with new material unless it was just a very small patch job.
A photo or two of what you've got might be helpful.
Unread 07-20-2021, 04:57 PM   #5
I took this to be the floor. Is this the wall or floor?
Unread 07-20-2021, 05:29 PM   #6
thedudemn
Floor
Hue
Unread 07-20-2021, 05:48 PM   #7
I didn't even consider floor after he said half-inch Hardi, Goldstein. Good catch.
Is there thinset mortar under the Hardibacker panels on the floor, Hue?
Again, photos of the damage would help. And more information is always better than keeping secrets, eh?
Is it screwed or nailed down?
Unread 07-20-2021, 06:20 PM   #8
If there's no thinset under the Hardi, I'd remove it.
Unread 07-20-2021, 07:31 PM   #9
I'd remove it either way. Really tough job to remove mortar without doing significant damage to the board, and if it starts delaminating, you could have a spongy spot that would allow vertical movement.
Unread 07-20-2021, 11:21 PM   #10
thedudemn
It's probably 1/4 underlayment not 1/2, . It's a 6'x3' floor. There's thinset underneath the hardi board.
Hue
Unread 07-21-2021, 07:49 PM   #11
You can try to remove the thinset but like Kevin said, the Hardi is easily damaged most of the time.
Hardi Board Advice ctg402 Tile Forum/Advice Board 27 01-28-2013 10:38 AM
Hardi Board to the tub AlanB Tile Forum/Advice Board 4 09-05-2005 09:33 AM
Hardi Board????? jenny26 Tile Forum/Advice Board 1 08-13-2005 09:52 PM
Hardi Backer Board JW Tile Forum/Advice Board 4 04-21-2004 05:48 PM
Hardi board dingleberries onetonseed Professionals' Hangout 2 04-17-2004 09:31 PM
