Unread 07-08-2021, 07:42 PM   #1
Wkhatri
How to get my Kerdi Pan and Bathroom Floor Level
Hey all, can you please advise if my diagram seems about right to get my shower area level with the rest of my bathroom?
I am installing a Schluter's Prefabricated sloped shower trays designed for KERDI-LINE linear drain (KSLT1220S), which is 48" x 48". I am going to cut the pan down to 36" x 46". 36" would be parallel to the linear drain, and 46" wide. As per Schluter when the pan is cut down to 36" it is 1 9/16" thick. This is for a curbless shower, so I will recess the sub-floor to be inline with the joists (not cutting the joist). However that still is a huge difference with a 3/4" subfloor. Also, I will be using the same 24 " x 48" tiles throughout the bathroom floor and shower area. My tile contractor will make the necessary relief cuts to ensure the tiles are sloped properly towards the drain. And I found and tested a product that makes slippery tiles matte and increase the grip drastically.
Please see my diagram and advise if my calculations look accurate? Also please advise how can/should I recess the subfloor to be in line with the joist, where the current plumbing is. That is not expected to move as it is inline with where the new drain would need to go. It's hard to see in the image, but that PVC drain is attached to the copper drain stack which is in the walls, and has an outlet/piece where the no hub is attached to it, so it cannot be turned either.
Waleed
Wkhatri is offline   Reply With Quote
Unread 07-09-2021, 07:25 AM   #2
Hi Waleed, .
It looks good to me. The foam floor must be absolutely level, though. There is not much slope to the drain. Check your subfloor for level.
Unread 07-09-2021, 06:21 PM   #3
Wkhatri
Thanks a lot John. Much appreciated. Fingers crossed it actually lines up.
Waleed
Tiling bathroom floor. Floor out of level. Not sure what to do next. averwo Tile Forum/Advice Board 8 09-12-2016 09:20 PM
bathroom floor not level mike123 Tile Forum/Advice Board 14 02-28-2012 06:16 PM
New basement bathroom - level floor? nadamson Tile Forum/Advice Board 14 05-26-2009 10:09 AM
best way to level bathroom floor...1" variation acid Tile Forum/Advice Board 4 06-08-2005 10:04 AM
How to level a bathroom floor?! tomcandoit Tile Forum/Advice Board 16 12-23-2004 08:35 PM
