Unread 03-05-2021, 09:45 PM   #16
xkse
More I think about it (and the more I read posts and the Liberry), I want to build my own.
What I've gathered, is a linear drain setup is different than a traditional pre-slope / clamping drain / liner etc etc.
Is there any tutorials for a linear drain? I'd like to be cost efficient, so cement board / liquid membrane on the walls was my plan.
For the linear drain, though, I've only seen the mud pre-slope to the linear drain, then kerdi as waterproofing. Can someone lay out the process for what I've described?
Nick
xkse is offline   Reply With Quote
Unread 03-06-2021, 05:39 PM   #17
xkse
I guess the process would be something like this: https://www.youtube.com/watch?v=YB2PQ4wd0Yg&t
Hoping someone can reply and lend some tips / advice for my situation.
Nick
Unread 03-07-2021, 08:34 PM   #18
xkse
So my post 2 up was wrong...I guess you can use a clamping drain or a topical drain with the linear setup.
Clamping drain on wood subfloor: standard setup, with subfloor-->tar paper/wire lathe-->pre slope mud bed-->pvc liner-->mud-->thinset/tile
Topical drain on wood subfloor: subfloor-->tar paper/wire lathe--> sloped mud bed to linear drain-->topical waterproofing (liquid based or sheet fabric based)-->thinset/tile
Am i on the right track? I'd like to hear your opinion on which linear drain style to use. The kerdi line drain is everywhere, then there are some clamping style ones on amazon, etc etc.
Curious as to your thoughts on what you would recommend and to point out any errors in my thinking.
Nick
Unread 03-08-2021, 06:52 AM   #19
Sorry you’re not getting attention to your question. I don’t set linear drains, but many other do. Do you want to rename this thread to something more generic?
Unread 03-08-2021, 11:32 AM   #20
xkse
Yeah that probably makes sense, could you do that?
Help Building Shower Pan with Linear Drain?
And then someone could hopefully assist!
Nick
Unread 03-08-2021, 12:28 PM   #21
Re-named it for you, Nick, let's hope for more traction.
Unread 03-08-2021, 07:08 PM   #22
Bump
Unread 03-08-2021, 07:58 PM   #23
I'd rather have a traditional pan liner set up than a surface type, myself. But the surface applied membrane only needs one mud bed which helps keep the shower floor thinner for curbless applications.
I don't care for the drain in that video. It looks like there's several glue joints in the drain that are just waiting to leak. Even though it would be more expensive, I'd rather have a one piece stainless steel trough. The drain below fit into a 3 inch cast iron clamping drain.
There are different types of linear drains. Get the type that goes with the waterproofing method you plan to use.
Unread 03-08-2021, 09:11 PM   #24
xkse
Thanks Davy
Yeah after reading through a lot of posts on this forum, I agree with you on that original video I referenced. My plan for waterproofing is either AD / Hydroban or Kerdi fabric over cement board for the walls. Haven't decided yet.
In terms of drains, do you have a link to the one in your picture? I'm not for or against either method, other than the fact that it'll be my first mud bed.
After rummaging through the forum, I found a long thread, including a post from Tiger Mountain Tile Inc on linear drains: https://www.johnbridge.com/vbulletin...2&postcount=52
He said he preferred the ABS ones.
This is a second floor shower, and I'll build it with a curb, if that helps sway your decision either way towards which "type" of linear drain I should move towards.
Nick
Unread 03-09-2021, 04:46 PM   #25
I don't remember what brand the drain is in that picture. The last plastic linear drain I installed was an Infinity drain. It was cheap in my opinion and wasn't made very strong. When I mudded against the plastic trough, just the weight of the mud caused the plastic to flex enough that the grate wouldn't fit. It did come with a spacer to keep this from happening which I did use but it still flexed the plastic. I ended up having to cut the grout out from against the drain and force the plastic to flex back to it's original shape. I wasn't impressed with the plastic drain.
Unread 03-09-2021, 06:33 PM   #26
xkse
Fair enough. I'll see if anyone else has some opinions on brands of linear drains, waterproofing preferences! Appreciate the opinion on the plastic linear drain.
Nick
Unread 03-09-2021, 11:09 PM   #27
If you’re planning Kerdi, I’d go with their linear drain as it will let you keep the whole floor buildup thinner, and it’s one less place for things to go wrong. Yes, they’re expensive, but they’re solid. And, I’d just use plain drywall on the walls, as Kerdi will work just fine, and the pieces are larger, easier to cut, and a lot less expensive. No need to tape the seams, as the Kerdi membrane will work better when applied. An alternative to cbu or drywall on the walls would be to use KerdiBoard since it’s already waterproof so you only need to treat the screws and seams to complete the waterproofing.
If your floor is flat AND level (doesn’t happen that often!) or you can make it meet those specs, you could use one of their linear drain foam pans. They’re easy to cut if oversized, and you could use KerdiBoard to build your seat.
Unread 03-10-2021, 05:48 AM   #28
xkse
Yeah that’s definitely an option I’m leaning towards. I’m in Massachusetts so Floor and Decor carries Kerdi products.
Everywhere I’ve checked for Noble and Laticrete seems to be distributors.
I’m going to go with a thin bed so one of the above 3 vendors is probably my answer. I’d like to do a price comparison but they don’t make it easy!
Nick
Unread 03-10-2021, 09:33 AM   #29
Nick, it'd be helpful if you'd add that geographic location to your User Profile. Otherwise the information will be lost before we leave this page.
Unread 03-10-2021, 10:37 AM   #30
xkse
Good point, updated!
Where do you buy noble or laticrete as a diyer??
I’m on a budget so my brain won’t let me proceed until I know all the options
Nick
Help! New curbless linear drain shower april lau Tile Forum/Advice Board 36 10-28-2019 07:11 AM
Eric's linear drain shower? EricO Tile Forum/Advice Board 29 11-05-2017 09:21 PM
Linear drain shower - CBU over subfloor? stephenson Tile Forum/Advice Board 57 09-06-2014 02:01 PM
Linear drain at shower entry Creative Construction Tile Forum/Advice Board 32 11-15-2012 11:17 AM
New shower with linear drain Bronco Guy Tile Forum/Advice Board 4 03-10-2011 03:29 PM
