Unread 09-14-2010, 06:36 PM   #46
mrjetskey
Smile
Thanks paul after looking again I guess the nails are up around 6" from floor it just looked lots lower and only shower I built I used redguard as it was bathtub/shower.I am in midst of doing upstairs master shower and remodling bath and was thinking of using spectralock or other epoxy grout,when my eyes fooled me.I realize now lots of builders still use the grey vinyl liners(at least they must as thats all lowes and home depot carries in conroe!Thanks for explaining my oversight,have a great evening>Marvin
Marvin
mrjetskey is offline   Reply With Quote
Unread 09-22-2010, 06:01 AM   #47
bppolivick
I think my plan of action I am going to buy a full unit from stonetooling.com for $45.00 and buy the mini part C's from Lowe's since their is really no cost difference and part C is already divided into four parts. I tried using the search button but couldn't find any advice on dividing parts A & B. Has anyone done this before? Any advice is greatly appreciated. A previous post mentioned a lot number on part C? Can anyone confirm this as to where it is? Thanks.
Brendon
bppolivick is offline   Reply With Quote
Unread 09-22-2010, 06:24 AM   #48
Brian in San Diego
Brian in San Diego's Avatar
Brendon,
Many people have divided the parts A & B. One way to do it is with an accurate scale. You can buy jewelry scales on eBay for less than five bucks. You can also measure by volume. Either way works. You might want to read the ginormous Spectralock thread.
The dye lot number is prominently displayed. I don't remember it's exact location but it's there. Not that it makes much difference. Spectralock is the most consistent in color even between dye lots.
Unread 09-22-2010, 07:03 AM   #49
zootjeff
Tool for the Job
Attached is a picture of a drill mixer I used for the epoxy grout mini-units.
I went to home depot and got a 2 foot section of round 3/16 iron rod . Bent it around a copper pipe into the shape below. I cut it with bolt cutters and rounded the edges with a grinder. It really saved me some time mixing up the grout.
All the paint mixers I could find at the home improvement stores were too intricate. I have a paddle mixer but cleanup would have sucked. This was super easy to just wipe off with a paper towel after each mixing..
This simple shape will mix the grout with the rounded edge while scraping out the corners of the bucket with the pointed edge. Don't over-think the design, this simple design can't really be improved without welds, etc... I tried rounding the edges at both sides, but then you won't mix all the grout..
I had enough rod to make two of them. If you make it too long, it will bend at the chuck under it's own weight if you spin it too fast. In the end 4 inches at the base and 10 inches long seemed like the sweet spot where I could run the drill full speed to spin off the excess without it self bending out..
zootjeff is offline   Reply With Quote
Unread 09-22-2010, 07:18 AM   #50
zootjeff
Here is another view of the mixer
Spectralock 2000 IG epoxy grout: Application advice ? tips? (its like silly putty!) MakenaTile Tile Forum/Advice Board 3 06-11-2010 10:46 AM
Epoxy Grout Advice CorCakalaka Tile Forum/Advice Board 5 05-22-2010 10:35 PM
Advice needed for Epoxy grout Stew Tile Forum/Advice Board 8 07-04-2008 04:35 AM
Need Some Advice - Regrount Epoxy ontop of Epoxy chefwong Tile Forum/Advice Board 1 08-28-2005 06:56 PM
Need advice on epoxy grout Michael Cavanaugh Tile Forum/Advice Board 2 03-23-2004 03:27 PM
