Unread 10-17-2016, 11:04 AM   #1
Snispel
Laminate to granite kitchen countertop backsplash issue
We had our kitchen laminate countertops replaced with granite. Now there's a gap between the countertop and the backsplash as narrow as 1/4" and as wide as 1/2". We've had 2 recommendations. One, caulk the gap, two, have tile guys back cut backsplash and insert a tile bead in the created even gap space.
Any better or additional advice out there?
Sara
Sara
Snispel is offline   Reply With Quote
Unread 10-18-2016, 12:21 AM   #2
Hi, Sara.
It's the duty of the countertop fabricator/installer to install the top to within tolerances of what you're installing for a backsplash. While installers LOVE installing thick 2 or 3cm backsplashes made from the same granite as the top because it allows for very easy installations that are fast-fast-fast....
They should ask you what you're planning for a backsplash as soon as they know you're not having them fabricate a matching granite backsplash. In other words, the moment they know you're not going with a thick backsplash that covers big air gaps on the back walls, they know they've got to be more accurate on the installation. It's time to get them back to do a little better job at fitting the top in place to reduce the gaps.
And no, there's not a real good excuse for not being able to do this, no matter how wavy your walls may be. There are LOT of countertop measuring tools from simple templates made with $10 worth of lauan plywood strips, to expensive laser measuring systems that are designed to allow fabrication in the shop to fit your walls and cabinetry to a reasonable degree.
Unread 10-18-2016, 01:14 AM   #3
Snispel
I should clarify.
We previously had a laminate countertop and a tile backsplash. We were required to have the laminate removed and the granite company came in and installed the new granite countertop. The new granite is thinner than the laminate, leaving the gap from the countertop to the backsplash vertically.
The granite people said we could replace the backsplash, shim the counters, or undercut the backsplash tiles to an even gap that would fit a tile bead, but were clear it was our problem. We are trying to sell this house as all our kids are grown now, so time is a luxury at this point. Our builder said he would caulk the gap if it were his problem. And I read somewhere that you could possibly grout a gap like that, and another that said to grout and then caulk.
And my head spins.
Sara
Sara
Unread 10-18-2016, 06:45 PM   #4
Ah. I see.
Grouting is inappropriate, because the interface between the top and backsplash moves a fair amount due to normal expansion and contraction of the materials. And because there's no real flexibility in the grout, it would very likely crack and look bad.
Why not show us a picture? Perhaps we can suggest something to take up most of the gap, such as a complimentary-colored bullnose or liner applied along the bottom of the backsplash. Then caulk the bottom of the new tile where it meets the countertop with a flexible sealant.
Unread 10-18-2016, 09:46 PM   #5
Snispel
I'll see if I can attach a couple.
Sara
Sara
Unread 10-18-2016, 10:04 PM   #6
Common color tile. I'd visit a tile shop or two to find a matching or complimentary-colored bullnose and apply it to the front.
Another option would be to have the countertop manufacturer make a 3" tall backsplash out of matching granite, but it would be considerably more money.
Unread 10-18-2016, 10:14 PM   #7
Snispel
Thanks for the input.
Sara
Sara
Selling - Kitchen Countertop Issue sawah3 Tile Forum/Advice Board 16 11-30-2006 08:43 PM
Kitchen Countertop Tile Over Laminate dhs1989 Tile Forum/Advice Board 1 11-16-2005 03:09 PM
Tile over laminate kitchen countertop gphillips Tile Forum/Advice Board 4 03-24-2005 07:07 PM
Tiling over a laminate backsplash in the kitchen aoldenburg Tile Forum/Advice Board 13 01-17-2005 02:28 PM
Granite Tile Countertop over existing laminate? tara Tile Forum/Advice Board 2 11-07-2003 08:26 PM
