Unread 03-11-2009, 01:46 PM   #1
aeg73
HELP for designing a step down walk in shower
We would like to create a step down walk in tiled shower in our bathroom. The current space is occupied with a toilet, but no other plumbing. The foreseeable issues look like space constraints. The step down area has 2 straight side walls and the back wall is part of a very slanted/sloped ceiling with a low knee wall area below it. I was thinking of using the sloped wall for the shower head & jet accessories, but don't know if there is enough space between that area & where the glass door would be? Are there minimum spacing requirements? We could put the shower head on the flat wall if necessary. What do you recommend for shower base, pre-maid or just go with the same tile used for the shower walls? Also, do you need cement board or can you use waterproof sheet rock? Any other info. is greatly appreciated. Rough dimensions of the space are approximately: 5' wide x 7'3" deep with a very angled ceiling 45 degree angle I believe. I can stand just starting to hit my head (I'm 5') about 40" deep into the area, if that makes sense.
Thank you!
aeg73 is offline   Reply With Quote
Unread 03-11-2009, 02:02 PM   #2
You don't want to use any kind of sheetrock in there unless it's covered with a moisture barrier. You don't want to stick tile directly to it.
Is this on a wood sub floor? How far down do you want it to go?
Unread 03-11-2009, 02:24 PM   #3
aeg73
Needing Additional Help
I corrected my dimensions as previously listed as estimates, but they are now accurate. What is in place right now, is painted sheetrock, bamboo floors & a toilet situated in this step down area. We wanted to keep the step down, which is needed due to the slant or you would hit your head if brought to level with other part of bathroom floor. I'm afraid that cement board is so thick it will take up too much space on that 45 angled wall? Please advise.
Unread 03-11-2009, 02:31 PM   #4
Read up on Kerdi, it's thin. There's a Schluter link to the right. Is this a concrete foundation or wood? The shower area is already lowered?
Step by step shower... make sure i got it right. GlassMakesMeCry Tile Forum/Advice Board 2 11-02-2006 05:52 PM
Help with designing and building a doorless shower madonna Tile Forum/Advice Board 20 09-02-2006 09:43 PM
Step by Step on Installing a shower cement pan TTTony Tile Forum/Advice Board 1 09-08-2005 06:28 PM
Step by Step instructions for walk-in shower Northboundgirl Tile Forum/Advice Board 4 07-20-2005 02:04 PM
Desperate for help in designing tile shower (and how to construct)... starlight Tile Forum/Advice Board 19 05-18-2005 07:42 AM
