Unread 11-21-2019, 07:19 AM   #91
Butch, I don't know how they are going to assess what certainly appears to be structural issues with the wall and subfloor support now that the floor is already down. Perhaps they will offer reassurances those deficiencies were addressed but, given all we've seen of this job so far, their assurances wouldn't give me the warm and fuzzies.
Unread 11-21-2019, 07:35 AM   #92
jackal2001
Let me clarify.
Everything is exposed as of now so repairs can be made.
New construction won't start for another 2 weeks or so.
Butch
jackal2001 is offline   Reply With Quote
Unread 12-07-2019, 09:08 PM   #93
jackal2001
Shower head and handheld rough in question (video)
Having a hard time finding good help so I'm hoping someone can assist with this question. My new tile contractor doesn't do the rough in and the plumber was supposed to check this but I guess he didn't. Please see video.
https://youtu.be/q82Cr10uja4
Butch
Unread 12-07-2019, 09:35 PM   #94
Is this a tub/shower? If so, you CANNOT run pex to the tub spout...the ID is too small, and it will put back pressure on the supply, and push water out of the shower heads unless you have a quality diverter valve to prevent it.
If you're asking whether the plumbing is at the proper depth, can't say without knowing what you are planning for the finished wall. There is a min/max allowed for the placement in order for the trim to fit. Note, some people do NOT like the look if the whole thing sticks out too far. Technically, it's okay if the trim fits, aesthetically, you may not like it. There is no easy fix for the valve body being too far out, and the 'fix', if it's an option, may not look great. Not all valves have an extension kit if the thing ends up too deep.
Unread 12-07-2019, 09:40 PM   #95
Jim, I've combined him again with his original thread and I think we see that no tub is involved. 'Course I been misled before.
Unread 12-08-2019, 05:55 AM   #96
jackal2001
No tub.
Allowing 1" for kerdi, tile, thinset.
Delta/Brizo fixtures.
Just need to know if mixing valve and diverter need to be on the same plumb line or not as they are. Also the shower head and handheld.
Butch
Unread 12-08-2019, 06:04 AM   #97
eurob
Not...Sure
I really don’t like those plastic nuts on your plumbing valve/diverter , especially in an enclosed wall area.
Roberto
Unread 12-08-2019, 06:06 AM   #98
jackal2001
Uh so what do I need to have the plumber do. He is coming back tue so things need to get adjusted or fixed.
Are these the wrong rough in fixtures for pex? Are they some universal that needs threaded pieces and ones should have been purchased for pex?
Butch
Walk-in shower not draining properly .. needs fix rexlan Tile Forum/Advice Board 10 10-24-2017 07:38 PM
Video: Shower Pan & Floor Install Hans47 Tile Forum/Advice Board 0 04-06-2006 12:25 PM
need advice on smoothing out slate shower floor so it drains properly 01yellowvette Tile Forum/Advice Board 10 07-08-2005 06:43 AM
Shower floor not levelled properly Kristen Tile Forum/Advice Board 2 01-30-2005 12:32 AM
shower floor not sloped properly dragonflyridge Tile Forum/Advice Board 6 09-06-2004 05:02 PM
