Old 05-15-2008, 03:56 PM   #1
scuttlebuttrp
Deckmud psi ?
Does anyone know the strength of deckmud?
Royce
Old 05-15-2008, 04:09 PM   #2
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
Off the top of my head, Royce, it seems like 2500 psi. is what I've read, but someone will surely correct or affirm.
I reckon there are a lot of determining factors to achieve that # , though.
Brad
Old 05-15-2008, 04:26 PM   #3
K_Tile
Member of Million SF Club!!
The psi of deck depends on the amount of cement in the mix, how hard it was packed and if you used admix. I would say it can range from 1200psi to 3000psi.
Old 05-15-2008, 04:39 PM   #4
http://www.johnbridge.com/deckmud.htm
"It has been suggested that deck mud should be mixed with latex additive instead of water, this to make the mortar more cohesive and to give it greater compressive strength. Well, I'm here to tell you that mortar made from sand, cement and water can easily attain a compressive strength of 3,000 psi or better. That strength is more than adequate for shower floors and other small areas. Adding latex in this instance is simply a waste of time and money."
http://www.johnbridge.com/vbulletin/...8&postcount=12
Old 05-15-2008, 04:51 PM   #5
opiethetileman
opiethetileman's Avatar
the psi in my head is - 2. is that what ya mean by deck mud
opiethetileman is offline   Reply With Quote
Old 05-15-2008, 08:21 PM   #6
nforcer2
out thick bed mortar is 4-5k
Robert Goff
LATICRETE Tech Rep
www.laticrete.com
nforcer2 is offline   Reply With Quote
