Old 12-15-2006, 07:05 AM   #1
John K
Maximum mud bed thickness
I have searched the site and can't seem to locate the answer.
What is the maximum mud bed over a concrete slab? I have a job I'm going to look at that has 7 inch recesses in the slab. Why, I have know idea. These recesses are to get mud and then mosiacs. They are walkways around a baptismal in a church.
Can I float mud that thick over cleavage membrane with lath and not have a problem?
John
www.precisiontilestone.com
John K is offline   Reply With Quote
Old 12-15-2006, 11:00 AM   #2
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
I'm not Dave Gobis but my opinion is as long as it is a slab on grade and you can really compact a 7" thick mudbed it should be no problem.
Maybe they can pour 5" of concrete in there before you show up, still gives you 2" to play with.
Old 12-15-2006, 04:51 PM   #3
GabeS
I remember seeing somewhere that the maximum thickness is 2". To be sure you should order The TCA Handbook.
GabeS is offline   Reply With Quote
Old 12-15-2006, 05:04 PM   #4
michaelhazuka
Union Tile Setter--Green Bay, WI
michaelhazuka's Avatar
I've done patch work at 3" in a 8' x 8' area, but I had to beat the snot out of the mud to compress it...I also put a membrane down before tiling.
I would have serious reservations about trying 7" though....I second the 5" pour with a 2" mud bed.....
Michael Hazuka- Journeyman Tile and Stone Setter
michaelhazuka is offline   Reply With Quote
Old 12-15-2006, 07:15 PM   #5
I can remember mudding a dining room that was once a garage and it was 5-5 1/2 inches at the thick end. I packed it good without any problems. I don't really know what kind of problems to expect, as long as it's packed good, it ain't going anywhere.
Old 12-15-2006, 09:31 PM   #6
MHI
Kitchen & Bath Remodeler
Use a portland slurry and 4000 psi concrete mix to fill it most of the way, if you are concerned about it.
Matt
MHI is offline   Reply With Quote
Old 12-15-2006, 10:10 PM   #7
Trivett_tile
hot boxing
Can u hot box a mud bed?say u are putting a mud bed in a shower, its 9 pm u like 2 shovels to finish but no more mud bed till the next morning?
Trivett_tile is offline   Reply With Quote
Old 12-16-2006, 05:35 AM   #8
John K
Thanks Guys,
I think I'll go with filling partially with concrete. If I use fast set concrete and do a direct bond, instead of poly and lath to seperate. Do you think there would be a stress factor going over new concrete?
John
Old 12-18-2006, 06:40 PM   #9
Davestone
Florida Tile & Stone Man
John, the way i understand the a.n.s.i, is anything over 31/2" of drypack needs more reinforcement, and more compaction, and a richer mix.I, myself would drypack it and not use a concrete mix,reasoning that two materials is less problems than 3 materials moving and compacting and setting. Trivett, you would need to bond the second mudbed with thinset, or a slurry, i would imagine.
http://Davestonestile.com
Old 12-18-2006, 10:18 PM   #10
Dave Gobis
da Man!
Dave Gobis's Avatar
Anything unbonded needs reinforcement. The limitation on depth has to do with the size of the aggregate. You lose compressive strength after a few inches regardless of the sieve size. Need some stone if your hitting 3", then it is concrete. If you pour concrete and top it with mortar you may get some differential shrinkage. Not a problem if the mortar is on a cleavage membrane, but may shear otherwise. Lath won't do the job, need wire if you try it.
Old 12-18-2006, 11:18 PM   #11
Ron
Tile Contractor
Ron's Avatar
I ran into that same problem and used 2 layers of Dow Styrospan insulation panels to build up to about 4".I set them in sticky thinset and then built the mortar bed on top of it with 2x2 mesh.
Makes for a good insulator and isolation membrane too.
Ron is offline   Reply With Quote
Old 12-18-2006, 11:25 PM   #12
Ron
Tile Contractor
Ron's Avatar
and the rest...
Old 12-18-2006, 11:38 PM   #13
Ron
Tile Contractor
Ron's Avatar
and this one...
Old 12-19-2006, 06:49 PM   #14
Ron, nice job.
