Unread 08-04-2015, 05:55 PM   #1
916tile
TileCoach
916tile's Avatar
Preferred Expansion Joint Material
What would your preferred expansion joint material be for a slate exterior balcony? Grout is customs natural grey.
Isaac Ostrom
Northern California
www.youtube.com/916tile
916tile is offline   Reply With Quote
Unread 08-04-2015, 06:31 PM   #2
If that's an aesthetic question, Isaac, I'd wanna get the opinion of whomever made the grout color selection.
In general it would be a flexible sealant meeting the applicable requirements of ASTM C920 for the application or one of the pre-fabricated strips available from a number of manufacturers for the application.
We'd need to know more about the installation to get any more specific, I think.
Unread 08-05-2015, 11:50 AM   #3
916tile
TileCoach
916tile's Avatar
I would like it to look as close to the grout as possible, and the balcony is already set so going with a Schluter part that has legs on it or similar is out of the question. Because it is slate, with an uneven surface I chose not to use the Dilex.
I was thinking a sanded urethene sealant with a backer rod. Again, the grout is Polyblend sanded Natural Gray.
Isaac Ostrom
Northern California
Unread 08-05-2015, 08:53 PM   #4
Tiger Mountain Tile Inc
Issac, I did an outside deck about 4 years ago. Slate and CBP natural gray. I ended up using backer rod and CBP's 100% color matching silicone and it worked great. It's a little soft for my tastes but it matched perfectly. The deck is in the weather and I just got an update on it earlier this summer and everything has held up great.
Their silicone meets shore A hardness which is what you need for exterior applications. Urethane is probably a better choice but you won't find a matching color like the silicone. It matched great.
James Upton DIYTileGuy.com
Unread 08-06-2015, 05:04 PM   #5
916tile
TileCoach
916tile's Avatar
Thanks Jim I'll think I'll try that. My Daltile might stock it.
Isaac Ostrom
Northern California
Do I need to cut an expansion joint? rjperket Tile Forum/Advice Board 5 12-19-2013 10:44 AM
joint material Traci Lee Professionals' Hangout 3 07-21-2010 04:34 PM
Expansion joint over cold joint whk Tile Forum/Advice Board 2 10-31-2007 02:01 PM
Kerdi ST tray expansion material spitty Tile Forum/Advice Board 6 10-28-2006 10:24 PM
Another expansion joint? Levi the Tile Guy Professionals' Hangout 11 01-31-2006 04:30 PM
