Unread 06-26-2010, 10:40 AM   #5671
grymes56
I don't think the brackets would react to themselves. I'm no metallurgist but so long as there are no dissimliar metals touching it shouldn't be a problem. I used regular lumber (not PT) and the brackets and SPAX screws were all zinc plated steel. zinc will only be touching more zinc.
I've never actually felt kerdi-board but am I wrong in assuming it wont hold screws from pulling out? Even if you used just as much steel I still dont see how it could be attached to the kerdi-board securely. Also - youd still have to use all of the Kerdi band and Kereck corners where it intersects the wall, and maybe even wrap the front edge - so it seems like you wouldnt even save much time.
Kyle
grymes56 is offline   Reply With Quote
Unread 06-26-2010, 10:58 AM   #5672
Shaughnn
Trowel Monkey
Shaughnn's Avatar
hi Kyle,
Screws won't find purchase in KERDI-board but washered fasteners will hold it in place. I posed using urethane to laminate the two sheets together and bond the whole thing to the steel frame. No need for anchoring hardware if done that way. As for the intersection between the wall and bench, no need for Kereck corners there. Kerdi the wall with tight holes at the brace penetrations and then seal the KERDI-board bench assembly to the Kerdi'd wall, making sure to ooze the urethane out to ensure a complete seal. If you want overkill, you can band the top joint and wrap it down both sides with Kereck corners, but that won't contribute to time at all.
Shaughnn
Unread 06-26-2010, 01:20 PM   #5673
gueuzeman
Ummm, here's one I finished last week. There's more that runs on the sides, the island, and a wine chiller area. Mural was painted by a local artist.
I cut the square ends off the ropes to make them run smoother, I think. And it made for more work, an added bonus.
gueuzeman is offline   Reply With Quote
Unread 06-26-2010, 01:57 PM   #5674
hbrothberg
hbrothberg's Avatar
Bill Vincent .... and Adam & Mike ... Sonic Burger install
I had the opportunity to visit with JB Tile Forum member Bill Vincent on his jobsite today.
Bill is a 3rd generation Laticrete user .... Adam is a 4th generation Laticrete user.
Henry
Henry Rothberg
hbrothberg@laticrete.com
www.laticrete.com
Office: (203) 393-0010 ext 202
Cell: (203) 988-1814
Full Disclosure: I am a 2nd generation Laticrete guy !
Follow my Blog: www.laticrete.blogspot.com
hbrothberg is offline   Reply With Quote
Unread 06-26-2010, 03:20 PM   #5675
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
Gueuzeman sometimes I wish that those ropes would come in both directions. So you can turn 90's and keep the flow of the rope going.
Would only work for all the same corners though ,, all right hand or all left hand.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Unread 06-26-2010, 03:31 PM   #5676
Bill no rack with that 8x8 quarry ??
Unread 06-26-2010, 03:55 PM   #5677
2MinutesHate
Adventurer/Patriot Extraordinaire
It looks like 6x8 or 7x8 porcelain to me. Unless you have a custom rack built for that tile, I guess you just have to stick to the grid.
Carlo
2MinutesHate is offline   Reply With Quote
Unread 06-26-2010, 04:00 PM   #5678
jondon
jondon's Avatar
Sweet mural
Henry guess they didn't know you were gonna be visiting, they didn't have they're proper shirts on.
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 06-26-2010, 04:08 PM   #5679
irish tileguy in michigan
Tile Contractor -- S.E. Michigan
irish tileguy in michigan's Avatar
Oh they new, and i bet Henry brought them sandwiches.
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
irish tileguy in michigan is offline   Reply With Quote
Unread 06-26-2010, 04:08 PM   #5680
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Carl,
Check the pitch on your monitor. Them's looking like 8"x8"s to me.
Gueuze, I'm glad you were able to hire some decent help. Those cuts look pretty good.
Shaughnn
Unread 06-26-2010, 04:24 PM   #5681
that's probably an Metro 105 Buckskin or American Olean Quarry 8 x 8 Shadow Gray.
I can tell from the 4th pictures tile in his left hand, has the quarry backing.
surprised it isn't an abrasive.
I had racks made for A-O, Dal and Metro quarry back when I did bigger commercial.
6x6 & 8x8
yeah, National account on Sonic's
http://www.metroceramics.com/pages/n..._accounts.html
Unread 06-26-2010, 06:46 PM   #5682
hbrothberg
hbrothberg's Avatar
Oh they knew, and i bet Henry brought them sandwiches.
Yup, I stopped by the Jobsite and chatted and then ran out and picked up sandwiches / subs for all 4 of us ...
Then I enjoyed a Jobsite lunch and chat with them......
Bill is a long time friend and I enjoyed visiting his Jobsite and chatting with him. And with Adam and Mike.
Somewhere around here I have a photo of myself around 8 years old with my brother mixing up a bucket of Laticrete 4237 latex thin set when my dad took us to do a demo for Bill's grandfather ....!
Henry
Henry Rothberg
www.laticrete.com
Last edited by hbrothberg; 06-26-2010 at 09:30 PM. Reason: found the photo ... and attached it ...!
Unread 06-26-2010, 06:53 PM   #5683
hbrothberg
hbrothberg's Avatar
Actually, Bill did have a Laticrete shirt on ...! It is just hard to see the Laticrete logo in the photo.
I'm thinking that I didn't send Adam enough Laticrete shirts to keep him properly dressed.
And Mike I hadn't met before...!
So ... I will be addressing my mistake by sending Adam and Mike a couple of Laticrete shirts.
And some more to Bill too ...!
Henry
Henry Rothberg
www.laticrete.com
Unread 06-26-2010, 09:52 PM   #5684
Kilauea
LT
Kilauea's Avatar
posted X Henry
By any chance were they BBQ?Those are some great in progress shots of Bill and the fam,by the way.Here's my weekly "progress".
1st-Tuesday-grouting/wrappin up walkin "subway" showers Laticrete bright white
2nd-Wednesday-flip back to the side job on the other side of east TX.H-Os want tub surround and entryway travertined as well...XLT and Permacolor Mushroom
3rd-Thursday-slam 500 sq ft 13x13 Laticrete XLT once again/13s pre-cut but inserts cut out of 12x12
4th-Fri-grout side job(home owner provides C-cure that needed to get screened out-rant)-flip back to "front" job to get/unload stuff-pallet limestone,12x24 porcelains,glass tiles,etc.etc....oh,and surprise!Thats wood that Im not gonna lay but guess ?? assumed Id just be that nice guy and transfer to door step
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 06-26-2010, 09:59 PM   #5685
Kilauea
LT
Kilauea's Avatar
*L.T.*
tandctile-dot-net
Shower Progress Pics Electrician Al Tile Forum/Advice Board 15 07-12-2011 11:38 PM
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
