02-25-2010, 11:47 AM
#3886
My camera was foggy or I need to learn how to use the right setting but I couldnt get a good pictures I dunno.
02-25-2010, 11:54 AM
#3887
Tile Contractor -- S.E. Michigan
Looks real good Rick
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
02-25-2010, 01:38 PM
#3888
yeah, i like how your pattern doesn't repeat too often like some of the other wood look tile planks installs.
02-25-2010, 01:42 PM
#3889
Brian I have a dry profile wheel for the grinder that in my opinion doesn't work all that well. It seems to leave things pretty rough so on stone I just hit it with one pass lightly and then finish shaping with the 50 grit diamond pad. I will have to try on porcelain but almost none of the porcelain I install is through body.
Lately I have been doing all my niche shelves and shampoo shelves with rounded fronts, clients see, to like the look and it adds a little space on an otherwise small niche.
Rick, I like the mud work, got any youtube videos of you mudding big rooms like that? Largest room I have ever mudded was just over 100 feet, as there isn't much demand for it here.
Jason W.
Superior Construction
Quincy, IL
02-25-2010, 02:35 PM
#3890
Jason,
try one of these DRP profile wheels on your wet saw.
you make one pass and you are pretty close to a finished product.
you can polish the marble or leave to to match a honed look.
with through body porcelain you can just leave it flat.
Travertine:
florida custom soap shelf shelves polished bullnose fabrication
Marble:
tampa orlando daytona jacksonville sarasota st petersburg clearwater brandon bradenton lakeland
Porcelain:
02-25-2010, 05:39 PM
#3891
bath tub protector..
i purchased the bathtub at home depot,and in the same isle the protectors are available..and for only 7 dollars ,my customer was more than pleased...and its reusable,but not likely.  ..
02-25-2010, 06:06 PM
#3892
If you've ever looked carefully at a well-laid hardwood floor, you'll quickly notice that no two boards line up at the ends. If it's been done right, no two boards will even be within six inches or so of lining up, and there will be no other discernible pattern either. Randomness of the seams is part of the classic look of a hardwood floor, and it also contributes to the strength of the floor's structure. Your planks will come in several lengths to ensure you never have to line up the ends...below is what I'm talking about..to prevent this i like using a measuring tape with centimeters not inches,it makes for a better breakdown of the staring lines...you can do 20 cm,40,60,80 and so on until you end up with a full plank again,and start all over..but not consecutively but small.big medium,smaller and big but the last bit should be smaller than the biggest piece which will be your new staring row.
02-25-2010, 06:32 PM
#3893
Curbless shower
John
02-25-2010, 06:33 PM
#3894
Rick - very nice looking floor - it is porcelain?
John
02-25-2010, 06:49 PM
#3895
Union Tile Setter--Green Bay, WI
centimeters not inchesby Orlando
...which is why we should go metric....had to do it on one job, and it was the easiest layout I've ever encountered since the introduction of large format tile.
....just saying.......
Michael Hazuka- Journeyman Tile and Stone Setter
02-25-2010, 07:02 PM
#3896
Very nice as usual John.
Steve
02-25-2010, 07:03 PM
#3897
Yes,
It was actually 12x24s cut in half by the tile company so alot of em varied in width. Kind of annoying. Laying it was a breeze. By the window the mud was 3" thick at the high spot it was maybe 1/2" thick. I bonded it with pure.
02-25-2010, 07:09 PM
#3898
sticky ricky did you install it like wood...use the left over peice and start the next row with it...should be little waste with thoose floors
02-25-2010, 07:13 PM
#3899
brian my oh my what big fingers you have...i would love to try them out on my nose
02-25-2010, 07:22 PM
#3900
Dan,
kinda. I chalked it for 3 tiles at a time so I couldn't do that but I had no waste at all.
