Old 04-27-2016, 08:44 AM   #1
Kimberly999
Need Help with Plank Tile Installation Issue
I have an issue that I hope you can give me some insight to. We are installing 6 inch x 36 inch plank tiles and realized that our walls in the hallway and kitchen where we are installing the tiles are not entirely straight. One side bows out at the end of the hallway, while the other side narrows in the hallway. We are running the tiles vertically down the hallway and are doing 1/8" grout spacing. My husband said the wall is off (gradually goes out) by 1 1/2 inches, so he had to cut all the tiles angled that ran against that wall, which looks fine to me because the grout lines are all even. But on the other side of the hallway where the wall narrows is where we now have an issue with the tile that continues and flows through the doorway into the kitchen. After continuing to keep the 1/8 inch grout lines straight as possible, he dry laid the first row of tiles for fit across the room and to the kitchen doorway that meets the hallway. Everything looked good. He started laying tile from the hall across the front of the kitchen then had to work his way back to the hallway, to avoid working into a corner because of an attached island that sticks out midway on the left kitchen wall. He noticed another variance, that started in the middle of the 3rd row, the same wall that narrowed in the hallway, now bows by 1/2 inch or more where the door frame ends. There is about 8 inches of wall after the door frame then there are kitchen cabinets. If he had laid the tiles straight and kept the 1/8 inch grout lines there would of been an angled gap of over 3/4 inch at the doorway. So he fanned the tiles, to meet the doorway tiles, (about 5 of them) but then the grout lines graduated out to over a 1/4 inch. He thought he could easily correct the variance in the next row where the tiles area narrows between the cabinetry but as he dry laid them for fit, he sees he will have trouble correcting the grout line spacing because of the staggered offset pattern and the long length of the tiles. He stopped laying the tiles at this point and we are looking for advice on how we should proceed.
Kimberly
Kimberly999 is offline   Reply With Quote
Old 04-27-2016, 08:07 PM   #2
Hi Kimberly. It's hard to give much advice on your floor since part of it is already installed and you need to tie into it. I can say this though, it's never a good idea to run the tiles parallel to every wall that you come to. You need to pop lines parallel to the longest wall and then cut the tiles to fit all the other walls. With lines spaced every 2 or 3 tiles apart, you can keep a certain size module keeping the joints the same size and in a straight line.
Old 04-27-2016, 09:32 PM   #3
Yep, you pretty much got what you've got at this point since a good bit of the tile is down. It helps to pop chalk lines through every room and check to see how square they are with each other.
About the only thing you can do at this point would be to try and correct it at a doorway, if you have one to work through. You would have to buy or make a threshold of some type that would "correct" the fact that the rooms are out of square, then basically start over in the next room with everything squared up.
Glass backsplash installation issue RNL Tile Forum/Advice Board 4 07-28-2015 10:52 AM
Plank tile over plank-covered pit...what to do? Nel Tile Forum/Advice Board 9 06-01-2015 09:05 PM
Wood Plank Tile Installation Advice, Please Chuck H. Tile Forum/Advice Board 9 04-03-2014 03:39 PM
Glass installation/legal issue TRAVIS (I.T.M.) Professionals' Hangout 25 10-15-2008 12:00 PM
Structural Issue - Removing Plank Subfloor & Replacing with Plywood? AaronB Tile Forum/Advice Board 9 02-21-2008 04:37 PM
