Old 07-29-2018, 03:02 PM   #16
jkk9
Question about placing 3 x 9 subway tile vertically. I’m concerned about keeping the lines vertical. I have a laser level - is that the best way to maintain vertical lines? Do i run complete vertical rows up the wall one at a time? Start at one side or in the middle?
Jim
jkk9 is offline   Reply With Quote
Old 07-29-2018, 03:41 PM   #17
workhurts
As much as I like using a laser, for something like that I prefer a hard edge to shove against the tile (like a 4' metal level or something).
Charlie
Old 07-29-2018, 04:04 PM   #18
rmckee84
rmckee84's Avatar
I agree, I use both all the time. Reference lines as well.
Ryan McKee
Old 07-29-2018, 05:47 PM   #19
Yep, I agree too. If I were to run 3x9's vertical, I'd get a straight edge long enough to run the whole row up to the top. Once you get a row run nice and straight, it'll help you run the next few rows. Just check every second or third row to make sure you have no dog legs in it.
Old 07-29-2018, 06:50 PM   #20
jkk9
When using a vertical brick pattern, do I complete one vertical row at a time or do I work horizontally and place one horizontal row at a time?
Jim
Old 07-29-2018, 07:52 PM   #21
Many installers would prefer to finish or mostly finish a vertical row at a time. Make sure you've got some horizontal lines snapped or marked on the wall to keep your staggers neat.
Old 07-30-2018, 07:47 AM   #22
jkk9
Good to hear as that's what i started doing.
Jim
Old 07-30-2018, 12:28 PM   #23
Jim, have you taped the cement board joints? I see thinset but no tape.
What Bubba said about horizontal lines.
Old 07-30-2018, 12:43 PM   #24
jkk9
Yeah, it's a bit hard to see as I also covered it with mortar but the new photo shows a small spot of tape I missed.
Jim
Old 07-30-2018, 12:57 PM   #25
jkk9
And I'll get those horizontal lines drawn when I draw the next set of vertical lines. Thanks for the reminder!
Jim
Old 08-19-2018, 08:59 AM   #26
jkk9
Using these sheets of marble/glass/metal for back wall of niche. The sheets weigh 3.5 lbs. Is TEC's SturiFlec 346 a suitable thin set for this application? The bag does not specifically list marble but does list ceramics, natural stone, mosaics, etc. I was wondering if the 3.5 lb weight would require a large tile mortar ...
Jim
Old 08-19-2018, 09:49 AM   #27
mark999
Best to use a white thin set. Grey will sometime stain some natural stone.
Mark
Old 08-19-2018, 11:04 AM   #28
Lou_MA
Marble = natural stone
Shouldn’t need a large format thinset for mosaic. You shouldn’t be having a lot of thinset behind those tiles.
Lou
Old 08-19-2018, 04:26 PM   #29
Hi Jim,
Tec SturdiFlex 346 mortar would be perfectly fine to set that marble. But with mesh-mounted mosaics in a vertical application, they will sag before they set. I’d choose another white mortar with non-sag properties.
Old 08-19-2018, 04:38 PM   #30
jkk9
Arrow
Originally Posted by Tool Guy - Kg
... white mortar with non-sag properties
Such as?
Jim
improving deflection from L/337 Hhunter22 Tile Forum/Advice Board 2 11-05-2015 06:04 PM
outside corners on a shower pan membrane DAX-G Professionals' Hangout 11 06-25-2012 07:36 AM
CPE Membrane preformed dam corners? Maccatack Tile Forum/Advice Board 2 12-13-2006 03:54 PM
membrane corners or preform coners? andrew390 Tile Forum/Advice Board 2 05-22-2006 05:23 PM
