Old 08-19-2018, 06:55 PM   #16
Hi Ed.
1. If you can cut the plywood at the red lines and get enough blocking under there for support, I see nothing wrong with it. If you can cut the hole in the plywood so the 4 nubs on the bottom of the flange can rest on the plywood, that would support the drain well and also leave about 3/4 inch for the felt, lath and preslope.
2. Any way you want to build out that wall will work. You might need to add another stud to the back wall in the right corner.
3. If I understand correctly, you want to add a jamb to each side, narrowing the opening. We see this quite often, sometimes 5-6 inches on each side, or more.
Old 08-21-2018, 11:01 AM   #17
ed001
I appreciate your helpful comments Davy, which tells me I'm not off base with my plan so far.
And here's one more noob question, for which I can't find much written about online. The most typical finished curb width that I've seen is in the range of 5-6", which starts with a 3 1/2" wide core of stud lumber.
Is a narrower curb width acceptable - something in the range of 4 - 4 1/2" ? (starting with a correspondingly narrower wood core).
Any reason to stay away from a narrower curb?
Ed
ed001 is offline   Reply With Quote
Old 08-21-2018, 11:14 AM   #18
Perfectly acceptable, Ed.
Old 08-21-2018, 11:37 AM   #19
ed001
CX, thanks for confirming that a narrower curb is ok. I'm going to lay out some lines for a 2" wood core and a finished 4" curb/walls, and see how that fits in with everything else.
Ed
Jon's Bathroom Remodel: Completed. EthylOH Tile Forum/Advice Board 176 10-01-2017 08:22 PM
starting a bathroom remodel (jeffs bathroom) boaty Tile Forum/Advice Board 22 09-15-2015 12:50 AM
Help with bathroom remodel Putt et Tile Forum/Advice Board 3 06-26-2013 07:47 PM
Jim's Bathroom Remodel jlmza2350 Tile Forum/Advice Board 6 10-04-2012 03:13 PM
First tile and remodel project - 9x12 bathroom remodel and 6x6 sauna kyle242gt Tile Forum/Advice Board 17 08-25-2011 08:42 AM
