Unread 05-22-2009, 03:07 PM   #1
Tiretool1111
Shower Project
Hello All, I am a long time reader, first time poster. I am redoing our master bath from a complete gut job. Am a little confused about starting the shower pan.Shower is 38'' X 48'' on a concrete slab. Should I put down roofing felt or not on the slab before I pour the preslope.TIA Ralph
Tiretool1111 is offline   Reply With Quote
Unread 05-22-2009, 03:20 PM   #2
HotinOKC
HotinOKC's Avatar
Hi!
No felt or lath.
I sprinkle thinset on the slab, mist it down with water, then dump the mud.
Mark
Support our Troops!
http://www.dav.org
HotinOKC is offline   Reply With Quote
Unread 05-22-2009, 08:09 PM   #3
Davestone
Florida Tile & Stone Man
Yeah, or you can mix the thinset as you normally would and trowel it on.Keep your posts on this thread and we can keep up with you.....and we might even answer you.
http://Davestonestile.com
Unread 05-22-2009, 08:21 PM   #4
Tiretool1111
Thanks for the fast response.More questions to come i'm sure. Ralph
Unread 06-05-2009, 07:36 AM   #5
Tiretool1111
Need Help
Layed my preslope yesterday and needs a little tweeking I think. A couple of spots are kinda level. Can I add more deck mud today. What is the best way? Should I use thinset to make it stick or can I just lay more deck mud before I put down the liner? Thanks,Ralph
Unread 06-05-2009, 07:39 AM   #6
muskymike
muskymike's Avatar
Hi Ralph, if you need to tweak it, yes, use some loose thinset to bond the deck mud to itself.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 06-05-2009, 08:02 AM   #7
Tiretool1111
Thanks Muskymike, When you say LOOSE,do you meen thin or dry on the thinset? Ralph
Unread 06-05-2009, 08:21 AM   #8
doublins
First-time Homeowner
He means add more water than you normally would so it's a "looser" or "more runny" mix than the normal peanut butter consistency you use for laying tile.
Chris
doublins is offline   Reply With Quote
Unread 06-05-2009, 08:27 AM   #9
Tiretool1111
That's what I thought. Dumb me, the thinset won't stick if you don't wet it.Thanks Doublin. Ralph
Unread 06-05-2009, 12:00 PM   #10
Tiretool1111
preslope
Got preslope tweeked,now have full bubble off on slope all way around with edges level.May get liner in tonight,don't know yet.Painters coming back in the morning to finish MBR. Thanks Muskymike & Doublin. Ralph
Unread 06-24-2009, 08:29 AM   #11
Tiretool1111
Thumbs up next step
Morning All, Had a few things sidetrack me but i'm ready to go now.Ready to install liner & Duroc in shower.Plan on using Redguard on entire shower except floor.Pretty confident on everything but the thinset.Could someone recomend what I should use on porcelin tile over Duroc ( modified-un modified-slightly modified). A specific brand & type available at the Big Box Store would be very helpful. Also should I put any kind of adheasive on studs behind Duroc or just screw it on every eight inches like recommened.Oh yea, would this be the same thinset to use on the floor over a 1/8 in. cork liner then Warmly Yours mats with the same porcilin tile? Thanks Ralph
Unread 06-24-2009, 09:16 AM   #12
Tile on Durock: Modified thinset. Versabond as a minimum.
Adhesive on studs: No
Thinset over heat mat and cork: Modified thinset. PremiumPlus.
Unread 06-24-2009, 09:40 AM   #13
Tiretool1111
Thanks bbcamp, I'm off to Homers. Ralph
Unread 06-24-2009, 03:30 PM   #14
Tiretool1111
Talking Back from Homers
Ended up getting Keraset from Lowes instead of Versabond from Home Depot.Was that a wise choice.Help at these two stores is not very helpful.$10 a bag vs $25 is not goin to make or break me on this project(275 sq.ft. of tile), just want to make the right choice.Thanks again All,Ralph any input would be appreciated
Unread 06-24-2009, 05:30 PM   #15
Tiretool1111
Talking
shower project jrc413 Tile Forum/Advice Board 13 08-12-2008 07:43 PM
shower project (one of many!) sandbagger Tile Forum/Advice Board 17 08-17-2005 09:08 AM
shower project shawny Tile Forum/Advice Board 1 08-08-2005 05:55 PM
New shower project Jackman Tile Forum/Advice Board 1 12-31-2004 11:40 PM
My shower project DaveC The Mud Box 6 12-30-2004 06:55 PM
