Unread 06-16-2007, 08:35 PM   #1
Grouthead
Kerdi membrane off-center over drain flange
I thought my first Kerdi project was going great guns. Then, while cleaning up, I noticed that I didn't align the floor membrane very well with the drain. The 6.5 inch circular hole was cut using the template, but after pressing the membrane into the mud floor it is 0.5 inch off center. The edge of the Kerdi drain flange appears as a crescent, 0.5 inch at the fattest, tapering down to 0.
I'm not sure how much leeway I have, but seeing as how it's at the low point in the floor I'm wondering if it is time to get acquainted with a tube of Kerdi-fix and smear it on. Your thoughts??
Grouthead is offline   Reply With Quote
Unread 06-16-2007, 09:24 PM   #2
Hi, I hope you'll give us a first name.
I don't think you have a problem. If I understand it correctly, you still have about an inch and a half of boned membrane all the way around. Trim the part that's hanging over if it's in your way. Shouldn't be a problem.
Unread 06-17-2007, 04:36 AM   #3
Grouthead
Many thanks John. Just what I wanted to hear.
Jim
