Unread 04-21-2021, 02:54 PM   #1
Venator
Is a 3/16 x 1/4 V notch trowel adequate?
I'm installing some marble mosaic sheet material, and the pieces are 2" diameter and 1/2 inch tall. I'm using Mapei LFT for the surrounding field tile (1/2 inch square notch) and will of course use the same LFT behind the mosaics. Trying to balance good coverage with not squishing a bunch through the mosaic. This is not a wet area.
Will this size trowel do?
Norman
Venator is offline   Reply With Quote
Unread 04-21-2021, 03:03 PM   #2
I think a 1/4X1/4 square notch might be a better option, especially since they are 1/2" thick.
But if you want the finished height of the mosaic to match that of the field you'll have to build up the surface under the mosaic. A 1/2X1/2 square notch puts down a lot of mortar.
Unread 04-21-2021, 07:22 PM   #3
Venator
Thanks Dan!
Norman
euro notch trowel drwcal Professionals' Hangout 9 11-20-2017 08:46 AM
V-notch trowel bcor Tile Forum/Advice Board 1 01-05-2013 11:48 AM
U-Notch vs Sqluare-Notch Trowel? Dan Clark Tile Forum/Advice Board 23 05-25-2008 03:29 PM
Trowel Notch Size kevinrmac Tile Forum/Advice Board 5 02-27-2008 08:30 AM
Notch Trowel Discussion Higher Standard Tile Professionals' Hangout 15 12-05-2003 08:54 AM
