Unread 04-20-2021, 08:48 AM   #1
Goosey
Window In Shower Help
Hey guys,
Been a long time lurker as i'm working on doing my bathroom but ran into something where i'm going to need to reach out for help. I'm currently going back and forth on what to do for the tile for the window i have in my shower. I'm thinking of cutting some "engineered stone" for the internal sides but am going back and forth on how to make the transition from tile to the window. Anyone have any recommendations/pictures to show what they did? The transition from edge of window to the wall of the shower is about 2.5" and my bullnose pieces are 2".
Chris
Goosey is offline   Reply With Quote
Unread 04-20-2021, 02:45 PM   #2
Welcome, Chris,
Do you plan to tile the entire wall all around the window? If so, I'd run my tile right up to all 4 edges. Then measure from the window frame to the face of the tile, then subtract 1/16th to 1/8th, and use that final measurement to have your e-stone cut to that width. Install the bottom piece first with a slight pitch towards then drain, then install the top piece, then finally the side pieces.
BTW, how many coats of Red Gard do you have on there? Did you use a film thickness gauge?
Unread 04-21-2021, 08:28 AM   #3
Goosey
I will be tiling up the whole wall to the ceiling. No thickness gauge but i pulled a small piece off and its close to the thickness of a cc. Probably put on close to 3-4 coats. Once the pinholes were gone, i stopped applying.
After more thinking, going to cut a piece of "engineered stone" for the sill and then top plate of the window. Then i'll use a schluter edge to make the corners look nice and then use cut pieces of tile to continue my pattern on the edges/sides of the window.
Chris
Unread 04-27-2021, 03:43 PM   #4
Goosey
In case anyone cares, here's what i ended up going with.
Chris
Unread 04-28-2021, 07:46 AM   #5
Nothin wrong with that, Chris.
Unread 04-28-2021, 08:09 AM   #6
Goosey
I'm happy with how it turned out. Never used the edging before but like how it looks.
Chris
Rotted tiled window sill and wooden window in shower Sean12 Tile Forum/Advice Board 6 01-15-2019 10:44 AM
Kerdi and Vinyl Retrofit Window over Aluminum Window mrkenneth Tile Forum/Advice Board 13 04-02-2017 01:05 AM
renovation losing window, backlight glass tile window? wkearney99 Tile Forum/Advice Board 1 04-22-2012 06:22 AM
Shower window - tile to window frame transition suggestions Fahrns Tile Forum/Advice Board 4 03-06-2012 01:21 PM
Shower Window tombat Tile Forum/Advice Board 4 07-28-2009 11:03 PM
