Unread 04-20-2021, 05:39 AM   #1
seodfac
Using Schluter Kerdi Shower Tray as Preslope
I need to put in the pan liner for a new shower this weekend before the tiler comes next week. He will do the final mortar on top of the liner, but its all me before that. I thought about using the oatey perfect slope under the pan liner to avoid tackling the preslope drypack hassle (first time), but it is not available. Cost aside, could you use a Schluter Kerdi shower tray as the preslope under the pan liner? The rest of the shower is board and redgard.
Adam
seodfac is offline   Reply With Quote
Unread 04-20-2021, 05:47 AM   #2
I would not, Adam. The tray gets a lot of it's strength from being covered with membrane and tile, so that point loads are spread out over a larger area. That's not something you'd get with a PVC liner.
Don't be afraid of a little mud. Even if you mess it up, you'll have almost no money in it, and maybe 45 minutes of your time. It's cheap and easy to do it over. If you need some advice with the basics, we're here to help.
Unread 04-20-2021, 07:37 AM   #3
Not to mention that you would not get the required 1/4" per foot slope using that foam tray as your pre-slope.
Deck mud is easy and cheap and the learning curve not steep. And if your first try isn't satisfactory, it's even easier and cheaper to remove it and try again. The second try will be satisfactory.
Advisable to use Schluter Kerdi Shower Curb if not using their shower tray? mindyrella Tile Forum/Advice Board 2 09-02-2015 11:31 AM
Can I Remove A Few Set Tiles From Schluter Kerdi Shower Tray? beaglegun Tile Forum/Advice Board 6 03-18-2014 09:24 AM
Minimum Tile Size in a Schluter-Kerdi Tray cdubea Tile Forum/Advice Board 5 07-10-2011 11:14 AM
FOR SALE-48" Schluter Kerdi Curb and Tray KarenK Tile Forum/Advice Board 3 03-19-2008 08:56 AM
anyone tried using a kerdi tray as a preslope? duke@bigred Tile Forum/Advice Board 6 10-07-2007 10:51 AM
