Found usc_block_11 empty, added this: [CODE] [/CODE]
Old 11-30-2007, 11:37 AM   #1
tjtile
Removing stains from ceramic floor tile
I am trying to remove stains which were caused by dripped insecticide during a tenting for termites. The drops seem like they have chemically burned the surface with a whitish powder residue forming on top. I tried scotchbrite type scrubbees and they seemed to work on some of the smaller droplets but not on the bigger quarter sized ones. They keep reappearing.
This is for a friend of mine who is a good guy and helps alot of people.
Any suggestions will be appreciated.
Tom
tjtile is offline   Reply With Quote
Old 11-30-2007, 12:26 PM   #2
flatfloor
"da Leveler"
flatfloor's Avatar
Tom, I'm going to move you to the cleaning and restoration forum. In the meantime can you find out the chemical composition or at least the name of the insecticide?
Jim Buckley
Tile Calculator
New Here? Read this!
Old 11-30-2007, 06:53 PM   #3
doitright
doitright's Avatar
Hi Tom
I'm with Jim. The more info the better. I also recommend him to cease using the green scotch brite pads, as they can possibly scratch the surface.
John Koessler
Old 12-07-2007, 07:08 AM   #4
tjtile
Chemical is called Vicane by Dow
chemical name is Sulphuroflouride. Any help will be appreciated.
Old 12-07-2007, 11:33 PM   #5
GeorgeT
StoneTech Rep
Send a message via ICQ to GeorgeT
Vikane is a neuro-toxin gas used as a fumigant. Its combined with another gas that acts as a warning to get out if your exposed... that second one is essentially tear gas... both nasty toxic.... however, what your description sounds like is a strong acid reaction... don't know the chemistry of it (since the possible culprit is a gas) but the possibility of an acid compound forming always exists.... could be damage that won't fix... could be a buffing wheel and polishing compound will take it out.....if it just comes back after you try to clean it with a pad it sounds etched..... no matter what those tiles may never be the same.
George T. O'Regan
Technical Services
DuPont StoneTech Professional
http://www.stonetechpro.com/
GeorgeT is offline   Reply With Quote
