Old 06-03-2018, 06:15 AM   #2881
Great work, John. You've come a long way in a fairly short time.
The trim plumbing is trendy, but I always think about having to wipe the shower down each time it's used. Things like that can really slow you down.
Old 06-03-2018, 11:09 PM   #2882
jwmezzanotte
jwmezzanotte's Avatar
Haha
With at least a couple year break too!
I went through the foam board thing. From Kerdi board, to Wedi, and still using a fair bit of hydroban board.
But once you have set on mud, you get spoiled👍
Old 06-03-2018, 11:13 PM   #2883
jwmezzanotte
Iím still using quicktete ďmortar mixĒ for brick/block. Iíve been adding lime, and have it nailed now.
That last tub I could toss a scoop of mud at the wall and it would hang. Itís about 3 days old now still showing no signs of shrinking or cracking. I think Iíve found the sweet spot in my mix.
To think I was getting my first jobs done with no lime, no wonder I struggled 😆
Old 06-04-2018, 05:53 AM   #2884
It's good to hear you've got the mix fined tuned. If it's the premixed brick mud then it would already have some lime in it. As long as the sand grit isn't too fine, it should work fine.
The Qwickrete scratch and brown I've been getting lately has had courser sand than usual. It still hangs well just makes a rough surface.
Old 06-04-2018, 06:10 AM   #2885
Back when I was doing expensive custom homes, all the floors were floated, so I would have a pile of sharp sand delivered. I always had three or four showers to float, too, and instead of trying to get in a small quantity of masonry sand I'd just float them with the sharp sand. Wasn't the easiest thing in the world to do, but it works. Takes a bit more thinset to set the tile. That's all.
Also, I don't think my mud ever hung on the hawk if I turned it upside down. Some guys like really sticky mud and some don't. 'Course, I always ended up with a fair amount on my shoes when floating walls.
Old 06-07-2018, 08:16 PM   #2886
John,
All i use is concrete sand for my mud and when i tile on it the next day i swear i use so much thinset. Never could figure out why compaired to tiling over cbu
Old 06-07-2018, 08:52 PM   #2887
Just In Tile LLC
Just In Tile LLC's Avatar
Shawn I just saw your dam post I do mine in the same order and also do the top the same I think. Using the L edges as your screeds to cut the top perfectly.
John Mezz: Mortar mix I had very dialed in, and not one crack, never added lime to it but I could imagine it would help things. You might have already said but how much lime do you add per bag. Guesstimate is fine
Edit: Just read the half of shovel of lime per bag
Justin
Old 06-28-2018, 08:53 PM   #2888
smifwal
now this is how you sling mud
https://youtu.be/vU9YOKk0_tE
Old 06-28-2018, 09:00 PM   #2889
Lou_MA
My back hurts just watching that
Lou
Old 06-28-2018, 09:21 PM   #2890
smifwal
You should watch the next video a little guy with a shovel
Old 07-02-2018, 07:01 AM   #2891
smifwal
How would a guy calculate materials needed for a scratch coat brown coat per sqft?
Old 07-02-2018, 05:35 PM   #2892
For scratch coats, I normally get 15-20 sq ft out of an 80 lb sack of scratch and brown. Most of my scratch coats are pretty thin since most tiles these days don't have mud cap.
Old 07-02-2018, 06:27 PM   #2893
smifwal
thanks Davy
Old 09-11-2018, 02:57 PM   #2894
Just In Tile LLC
Bench I floated today with a plywood jig. You can see a smidge of baking soda I used to set the face up a little quicker.
Justin
Old 09-11-2018, 03:32 PM   #2895
Nice job.
mud work larrylou Professionals' Hangout 117 10-30-2011 02:33 PM
Where's that mud work how to thread? MGB Creative Tile Tile Forum/Advice Board 4 09-18-2008 05:26 PM
Mud work Rd Tile The Mud Box 2 04-16-2008 08:10 PM
Mud Work Charles P Professionals' Hangout 2 01-11-2008 06:33 PM
Methods for finding commercial work K_Tile Professionals' Hangout 23 10-31-2002 03:57 PM
