Unread 09-13-2019, 10:33 PM   #1
nickelec
How does this look to the pros
Hey all just got my floor done wat do the pros think?
Sent from my SM-G965U using Tapatalk
nickelec is offline   Reply With Quote
Unread 09-14-2019, 07:51 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Hmmm, you're asking for critique?
First two photos are out of focus. Can of WD-40 looks lonely. I like grout floats with blue handles.
Like that?
Peter
Unread 09-14-2019, 07:53 AM   #3
nickelec
Exactly lol wd40 was a marker for a repair not to step on
Unread 09-14-2019, 08:04 AM   #4
rmckee84
rmckee84's Avatar
I'm not a fan of the stairstep look with planks, but aside from that it looks ok in the pics.
Ryan McKee
Unread 09-14-2019, 09:49 AM   #5
Lou_MA
I would’ve used a crack iso membrane over the slab. And the thinset should’ve been notched parallel to the short edge of the tile. And it doesn’t seem as if there’s enough of a perimeter joint. Otherwise looks fine from here.
Lou
Unread 09-14-2019, 10:26 AM   #6
nickelec
He used laticrete hydro ban on top of the slab
Unread 09-14-2019, 11:26 AM   #7
Looks like you have a random stagger, I like it.
Unread 09-14-2019, 11:29 AM   #8
nickelec
Yes I was very adamant about not having standard grout joints
Unread 09-14-2019, 11:58 AM   #9
Like Lou said, running the thinset notches the short direction will give better coverage but that's not a rule I always follow. I do skim coat the backs of every piece which I feel is very important. For many years we didn't even do that and that was with thinsets that didn't have near the bond of today's thinsets. Nice floor.
Unread 09-14-2019, 12:53 PM   #10
nickelec
Ty
Unread 09-14-2019, 06:24 PM   #11
Carbidetooth
Hmmmmm
Are you sure he used Hydroban? I don't see any on that surface and it's easy to identify. It's kind of a dark sage green and would be obvious.
Peter
Unread 09-14-2019, 06:32 PM   #12
nickelec
He definitely did iwas there when it was put down but the compound dust I guess took the green away
Unread 09-15-2019, 07:17 AM   #13
RichVT
Vermont Remodeling Contractor
If the Hydroban was put down before the drywall, then the floor probably should have been covered to keep it clean and protected.
Rich
RichVT is offline   Reply With Quote
Unread 09-15-2019, 07:34 AM   #14
Lou_MA
Was hydroban put down over the entire floor? Aside from the buckets, I can’t see any evidence of it applied on the floor. And as mentioned, it’s an obvious green.
If there’s enough drywall dust that it completely covered the Hydroban, I’d be concerned about it being a bond breaker.
Lou
Unread 09-15-2019, 12:49 PM   #15
smifwal
I am going to guess that this area is wet, maybe spilled water and that appears to be about the color of hydro ban and I hope that your installer was wiping the floor down as he went to clean off all dust. But with the amount of dust in the picture you would had to change water buckets about every 10sqft if you were lucky. So sweeping and then mopping then wiping down as you went would have been better. As Lou said that is a serious bond breaker
OK Pros I need your help! DJ123 Tile Forum/Advice Board 16 07-15-2014 07:39 PM
Need some advice about the pros, from the pros Liam Taylor Tile Forum/Advice Board 8 09-11-2013 07:39 AM
My hat is off to the pros!! Thanks! Daveco2 Tile Forum/Advice Board 3 01-01-2010 05:06 AM
Help from Pros, PLEASE! damet Tile Forum/Advice Board 7 07-15-2009 02:23 PM
A ? For The Pros. How Do you....... MikeC Tile Forum/Advice Board 25 10-18-2002 12:37 PM
