Unread 08-09-2019, 09:38 AM   #1
Margaret Murray
Restoring terracotta mosaic tiles
Hi there,
I feel like I'm close to finishing this renovation of a former patio-turned-kitchen floor, but have a few questions. The pics attached Name:  IMG_0806.jpg
Size:  52.3 KBshow the type of tile, the amount of grout in between, and the variations in the cement throughout the floor.
I've never had a problem with efflorescence on this tile before, but it may be that it's now showing because I've cleaned it so deeply and am now down to bare cement. Name:  Tile Pic 2.jpg
The house was built in the 50s and I think this tile was installed then, as well. It's a cement block house with a crawl space underneath and I live in humid Florida.
I've done the water drop test and it just sits there, so I'm assuming this tile is somehow sealed.
Here's the cleaning process so far:
1. Used Grout Sensation first, which cleaned the majority of the grout.
2. Used Greased Lightning next on high traffic areas and near the stove and oven
3. Used 50/50 vinegar and water to clean the tile and grout, hoping that would remove the whitish areas.
My questions are:
1. Are these white areas efflorescence or simply discolored cement?
2. Should I keep cleaning with vinegar or is there a non-acidic commercial solution available? How long should I wait or how many applications should I expect to do before it's resolved?
3. To get the grout to a somewhat even color, is there an option beyond hand painting the grout? I've got some grout renew, but am nervous about leaving it on long enough to penetrate the grout because I'm so nervous that it's going to stain the tile. Any sort of wipe-on/quick acting grout refresher that won't stain the tile?
4. I'm usually all for the natural, old-fashioned way of doing things, but I'm worried about the upkeep involved if I go the linseed oil/beeswax route. But I'm thinking that might be an easy way to even out the cement color by tinting the linseed oil blend a tiny bit. Between the different porosity of the two surfaces (grout and tile), I think it might look good. Am I thinking rationally in that regard or no?
Margaret
Margaret Murray is offline   Reply With Quote
Unread 08-09-2019, 01:37 PM   #2
Hi Margaret,
So I guess the black areas are the original color of the grout?
I would curtail the vinegar treatment. Scratch the surface of the grout with an old screwdriver or something else sharp in order to see what's under the surface. See if you find black grout. We'll go from there.
Unread 08-09-2019, 03:11 PM   #3
Margaret Murray
Smile
Hi there, John!
Thanks for giving me permission to stop the vinegar, although I have become used to the smell after three days of cleaning with it
The areas where it looks like black grout are really dirt and grime that has mostly been cleaned away. The lighter gray areas are what the original grout, for lack of a better word, is. It looks like cement to me, and it's pretty flush with the tile.
Thank you!
Margaret
Unread 08-09-2019, 03:37 PM   #4
Margaret Murray
Before and after pics
Here are some images that give a broader view of the tile and what it currently looks like.
Name:  Tile before.jpg
Name:  tile after.jpg
Margaret
Restoring terracotta floor (Mexican tile) lzena Cleaning, Restoration and Sealing 37 09-21-2017 10:46 PM
Sealing Terracotta tiles - which sealer? omartileguy Cleaning, Restoration and Sealing 2 08-06-2013 08:24 AM
restoring small bathroom...with shower mosaic pictures kahuna Tile Forum/Advice Board 39 01-09-2011 02:59 PM
restoring saultillo / terracotta floors screamerUSA Cleaning, Restoration and Sealing 2 05-06-2008 06:19 AM
cleaning terracotta tiles jimjimracing Cleaning, Restoration and Sealing 2 09-07-2007 05:48 AM
