Unread 06-05-2019, 08:31 AM   #1
Randy M
Small bathroom floor replacement
Hi,
So great of you guys to help the DIYer’s out here.
Hoping some of you can take a look at my plan of attack. Thanks.
Replacing 8”x 8” ceramic tile with 1’ x 2’ tile on a 5’ x 8’ upstairs bathroom floor. (5’ x 11’ with tub) Removed old tile set in mud bed with mesh. Removed 3/8” plywood that was under mud bed.
Existing 3/4” by 5-1/4” boards running diagonally on top of 2” x 10” joists. Unknown wood type.
Deflection is 2143.
The floor seems flat except by the corner against tub where the top of the wood deteriorated a little from being wet. Will check entire floor again after screwing boards down tight.
Add blocking where hole is from laundry chute and fill in with pieces of 3/4”. Or can I just install the plywood over the hole?
Screw down existing boards with #9 x 2-1/2” deck screws.
Pre-drilling the boards and 2 screws per board where it crosses over joists.
Install 3/4” (23/32) douglas fir sanded exterior ACX plywood with 1-1/2” deck screws avoiding the joists. Perpendicular to joists and no ply ends line up.
Leaving 1/8” gap between plywood pieces and 1/4” from walls and tub.
Is screw pattern 6” on edge and 8” in the field? 2” from edge?
Should I fill any of the gaps with something?
Is backerboard the easiest for a 1st timer? Hardy Backer ok to use? Any recommendations?
Enough for now. I’m sure I’ll have more questions later.
Randy
Randy
Randy M is offline   Reply With Quote
Unread 06-05-2019, 10:23 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Hi Randy, I can almost guarantee your deflection number isn't L2143.
I suspect you're figuring that by size of room. Unless there's another room same size directly below and those walls carry that weight to foundation...well, I've never seen such.
Span is unsupported length of joist. And on a second story, the end supports are defined by load paths to foundation, not partition walls.
Let's figure that out and proceed knowing we're good framing-wise and go from there.
Peter
Unread 06-05-2019, 12:27 PM   #3
Randy M
Definitely bearing walls on both sides of the 5' width(footings below both). Same size room below (1/2 bath and laundry room) I used 5-1/2' on the deflecto. Thanks for making me double check. Measure twice, cut once.
Randy
Unread 06-05-2019, 12:49 PM   #4
Carbidetooth
Hmmmmm
That's unusual, maybe an addition?
Anyway, I'd cut diagonal the unsupported boards to center of adjacent joists and patch in new 1x6 and the rest as you've described.
Yes on screw spacing. Gaps in tile backer need mesh tape and mortar.
I'm a big fan of decoupling membranes like Ditra or Stratamat. Less so of tile backer, but it's cheap and will work. Hardie is thirsty, beware when setting tile, mortar on the loose side and don't dawdle after combing, lest it skin over. Check for coverage on first couple of tiles.
Peter
Unread 06-05-2019, 03:37 PM   #5
Randy M
Thanks Peter,
Does it matter if thinset gets into the spaces between the plywood?
Should I silicone them or ?
Randy
Randy
Unread 06-05-2019, 05:25 PM   #6
Carbidetooth
Hmmmmm
Nope, it doesn't matter. Seems counterintuitive, I know, to fill space you specifically left, but it's standard fare. I wouldn't fill it with silicone, whatever thinset mortar gets in there is OK....really.
Peter
Unread 06-07-2019, 08:20 AM   #7
Randy M
Do I need to pre-drill the the plywood?
Or will an 1-1/2" self drilling screw w/shank work.
It seems like all the screws are advertised as no pre-drilling needed.
Randy
Unread 06-07-2019, 09:15 AM   #8
Carbidetooth
Hmmmmm
Randy, there are those that would say yes, but I rarely predrill. The concern is what's called screw jacking and it manifests if entire shank is threaded.
I use these for all kinds of things. The upper shank is designed to kinda hog out area that would be pre-drilled. I'd actually use 1 3/4" for a job like yours. Gets a full bite in boards and leaves some head scratchers below. Not enough to be concerned about hitting joists, though. Actually, I'd likely use these for screwing boards to joists as well unless tops were soft and I needed the extra length.
Peter
Unread 06-07-2019, 09:58 AM   #9
Randy M
Thanks again Peter,
So I'll use the 1-3/4" for both boards to joists and then plywood to boards.
No pre-drilling needed.
Randy
Unread 06-07-2019, 11:46 AM   #10
Randy,
Peter certainly has more experience than I do but from my DIY experience 1 3/4" screws through 3/4" ply may not get enough bite into the boards below. I tried that length - some would bite while others would spin. I'd go with a minimum of 2".
I was screwing down a 2nd layer of 3/4 ply on top of 3/4 ply, so maybe the 1 3/4" into your floor boards will work better.
Unread 06-19-2019, 09:10 AM   #11
Randy M
Not all diagonal subfloor boards flat
Thanks for everyone's help.
I’ve screwed all diagonal boards to joists & repaired hole.
I’m using a 3’ & 7’ straight edge to check for flatness.
In a few spots a portion of one diagonal takes a dip of 1/16 – 1/8” between two boards that are flat.
Is it ok to set 3/4” plywood now?
Maybe not screw into low spots or does it matter since the boards on both sides of low spots are flat?
A piece of felt or roofing shingle in low spots?
Randy
Unread 06-19-2019, 09:22 AM   #12
Carbidetooth
Hmmmmm
I'd overlay without regard to minimal low spots. The plywood will sort of average things out. I almost hate saying that because it sounds so ambiguous, but I've never had it become a problem.
Just say no to felt or shims.
Peter
Unread 06-19-2019, 09:26 AM   #13
Originally Posted by Randy
...a portion of one diagonal takes a dip of 1/16 – 1/8” between two boards that are flat.
'Fraid that doesn't compute for me.
You want to screw the 3/4" plywood at the same fastener schedule throughout. If you end up with an insufficiently flat floor, you'll need to deal with it at that level. I can envision a scenario where filling a minor depression with roofing felt or similar might be advisable prior to installing the plywood panels, but I'm not sure what you have there.
I'm one of the people Peter said would recommend pre-drilling that 3/4" plywood before installing. Maybe some folks can get by without doing so, but I have insufficient gravity to guarantee no screw-jacking with anything thicker than nominal half-inch material.
Unread 06-19-2019, 10:00 AM   #14
Randy M
So i'll install plywood as is & then check for flatness and deal with a self leveling compound or something if needed.(Hopefully not)
I only weigh a 140 lbs so I'll drill pilots.
Are the pilot holes the same size as the shank on the screw so no threads bite into the plywood?
Randy
Unread 06-19-2019, 10:17 AM   #15
No bigger than the shank size, Randy. The threads will still bite into the plywood, but will strip out quickly. And if you use fasteners that have more than 3/4" of unthreaded shank below the head, you may get by without the pre-drilling. I'd still pre-drill 3/4" material, but that's entirely up to you.
axa small bath axa Tile Forum/Advice Board 21 02-03-2013 04:53 PM
Subfloor replacement patch - biggie or small? Topspin Professionals' Hangout 6 08-21-2010 07:11 AM
Bath tile removal and replacement Mike DIY'r Tile Forum/Advice Board 6 06-24-2009 02:50 PM
? on small Bath remodel aletamarie Tile Forum/Advice Board 32 11-15-2007 07:17 AM
no barrier in small bath Robert Hilborn Tile Forum/Advice Board 1 03-06-2007 06:24 AM
