Unread 07-21-2010, 01:41 PM   #1
Traci Lee
joint material
Hey guys,
Got a call from a client we did a ton of stone in, the only stuff we didnt do was the fireplaces(riverrock) So the mortar in the face and sides is rubbing off, and the installer is saying it was a bad bag of mortar, and wont come back to fix it. I want to help, these are long term clients but Im no stone mason, Im a tilesetter.... I want a mortar that is exceptional with high heat, fibre content for strength and definitley something that wont rub off. Any ideas? I talked to the mapei rep and he said Ultracolour HTC with an additive might be a go, but he didnt sound so confident about the application (this is a huge fireplace, wood burning)
traci lee
Traci Lee is offline   Reply With Quote
Unread 07-21-2010, 03:21 PM   #2
Cain
Cain
http://www.laticrete.com/mvis/produc...ductid/55.aspx
Haven't used it but Laticrete has a masonry veneer system of products that might be just what you need.
if you do go this route let us know about your experience. I for one am quite curious.
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Unread 07-21-2010, 04:30 PM   #3
Jim Doane
Custom Masonry Contractor
Traci , Is the so called bad batch of mortar from the stone mason near the firebox? How wide are the joints? Is it natural river rock or man made? What is behind the stone ? Durarock, Concrete block etc? Jimbo
Jim Doane is offline   Reply With Quote
Unread 07-21-2010, 04:34 PM   #4
Jim Doane
Cain , I have used alot of the MVIS systems components. Ask away Jimbo
what material do i use Aurora Tile Forum/Advice Board 1 04-12-2010 04:37 PM
Expansion joint over cold joint whk Tile Forum/Advice Board 2 10-31-2007 02:01 PM
new material RexModeling Professionals' Hangout 3 09-08-2006 09:54 PM
Soft Joint/Hard Joint MichaelJ Tile Forum/Advice Board 3 07-20-2004 11:07 PM
Expansion joint over "cold joint" Stew Professionals' Hangout 8 04-14-2004 06:37 PM
