Unread 06-28-2009, 09:10 AM   #1
shower KC
To Schluter or not to Schluter, that's the question...
I'm in the second year of a 10-year total remodeling of my 40-year-old home, and the current project is making an 8x20 room that was second floor attic into a full bathroom and separate laundry room for a guest bedroom suite. The remodeling crew (I'm doing the finish work, not rough-in) wants to use the traditional mortar base for the 4x7 tiled shower, I'm concerned about the weight and possible cracking/leaking as my house has had some settling issues. I'd rather use the Schluter system, but not having used it personally before (neither has the remodeler) I'm not sure what to do...should I let them do what they're used to, or put my foot down and demand the Schluter system? I'm paying for either, so cost isn't the issue...quality, longevity and lack of leaks are the most important. Thanks in advance for your input on my dilemma!
shower KC is offline   Reply With Quote
Unread 06-28-2009, 09:23 AM   #2
gueuzeman
Well, between the mud bed and the cement board you are talking about a bit of weight vs. gypboard and styrofoam for the kerdi shower. Properly built, either one will work fine, the comfort in the Kerdi (or any surface applied membrane system) is that the walls and shower pan never get wet, removing the possibility of mold.
gueuze
gueuzeman is offline   Reply With Quote
Unread 06-28-2009, 09:33 AM   #3
I agree, a properly built traditional shower pan is fine if done right.
on the other hand a Schluter shower which no water getting to the substrates is better.
^^Check out our Blog^^
Unread 06-28-2009, 09:49 AM   #4
jgleason
jgleason's Avatar
I'd go Schluter Kerdi. To me it is a huge benefit keeping the water out of the mud bed and not having to worry about weep holes getting blocked.
Unread 06-28-2009, 10:20 AM   #5
Welcome, shower KC. Please put a first name in a permanent signature line for us to use.
The difference in weight amongst the various methods of building a shower pan should not be a consideration at all. Your structure should be able to accommodate any type of shower you elect to construct, and if it's not, it should be improved such that it is. It's really that simple. If and extra hundred pound is going to make a structural difference, you have a structural problem.
Consider that you also couldn't even have more than one person in the shower at a time if your structure were that lacking. Or you couldn't even have one full sized MIL in there, or even upstairs, if that were the case.
But I certainly agree with those who recommend the Kerdi shower system. Having your waterproofing directly behind the tile is a considerable advantage to my thinking.
Unread 06-28-2009, 10:49 AM   #6
Deckert
Regardless of what system you choose, make sure you have an installer that understands it and can execute it properly. I'd rather have an expertly constructed mud shower, than an incorrectly constructed Kerdi/Wedi/Noble/Hydroban/Whatever shower.
I'm NOT SAYING not to use your current guys. I'm saying make sure they get all the info they need if you have them use a system they aren't familiar with. We can help with that if needed and answer questions
Brannigan
HeenanGC.com
Unread 06-28-2009, 12:12 PM   #7
Based on the number of do-it-yourselfers (thousands) who have successfully completed Kerdi showers, it shouldn't be a problem for a pro who has the proper instruction.
Unread 06-28-2009, 12:29 PM   #8
Deckert
Absolutely John. And thats what I was getting at, don't just drop a Kerdi kit in their lap and make em use it. Make sure they get any and all the info they need to do it right.
Brannigan
HeenanGC.com
Unread 06-28-2009, 02:54 PM   #9
dhagin
...and tell 'em to come here with any questions...
dana
Epoxing a Schluter or Schluter like profile pitterpat Professionals' Hangout 8 02-07-2008 06:09 AM
Schluter curb question... tileguy88 Professionals' Hangout 4 05-20-2007 07:41 PM
schluter question dmpepin Tile Forum/Advice Board 2 01-17-2007 04:55 PM
Schluter Question GolfnRL Tile Forum/Advice Board 3 04-21-2004 04:28 PM
Schluter Question robwub Tile Forum/Advice Board 1 08-20-2003 02:12 PM
