Unread 11-12-2011, 09:19 AM   #1
nickromano
Remodeler
Proposed new design values for Southern Pine
Currently Southern Pine Inspection Bureau (SPIB) has new design values they have proposed for SYP. You can find more about it on their site:
http://www.southernpine.com/new-design-values.asp
If you have a building with SYP and just barely meeting L/360, in reality (after they adopt these new standards) your not meeting L/360. Just to pull an example out of the proposed new span chart, 2x10s are now at 16'-1" and with the proposed new span chart they will be 14'-11". That is to meet L/360 30 psf live load.
I'm sure everyone knows, but lumbers not what it use to be.
Nick
nickromano is offline   Reply With Quote
Unread 11-13-2011, 08:35 PM   #2
Hammy
Hammy's Avatar
From what I read about it,,,, it is due to the fact the SYP is on a fast trac for growth and they dont think it is as strong. Bad thing about this is there has been very little input from those outside the grading assoc. from what I have read.
Existing inventories will be automatically be devalued causing a loss to lumber yards.
Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Unread 11-14-2011, 06:20 AM   #3
gueuzeman
The 2x joist should go the way of the rotary phone. The lumber isn't as good, and should be devalued. TGI's and other new stuff are the way to go.
There will always be a need for dimensional wood, but.....
gueuzeman is offline   Reply With Quote
Unread 11-14-2011, 07:18 AM   #4
koihito
A person, like you.
koihito's Avatar
TGI's do have draw backs. In my (admittedly personal) experience dimensional lumber is far more tolerant of termite and water damage. TGI's fail with minimal damage whereas dimensional lumber will sustain a fair amount of damage before failing; These may not be issues everywhere, but here in NC where termites and crawlspace moister cause a lot of problems it is a consideration.
TGI structures also burn much faster according to our local fire department. Our fire chief sees them as a safety compromise. I have no idea if he is right but...
Nate
www.mikoskiconstruction.com
Unread 11-14-2011, 07:26 AM   #5
Part of the problem, perhaps all of it, is that the grading standards changed some years back and certainly not for the better. I don't recall exactly when it was, but I remember the change clearly. It was fairly dramatic and I don't recall any commensurate changes in anyone's span tables. This change is overdue in some opinions.
While I like dimension wood and have employed some miles of it over the years, I certainly agree with Gueuze that engineered wood is the way to go when verifiable characteristics are important and straight (or properly cambered) pieces equally important.
Unread 11-14-2011, 07:38 AM   #6
Bruce H
Nate, your fire department is absolutely correct, at least in the opinion of the presenters of a seminar I attended a couple years ago. The seminar was about how buildings of different construction types react under different fire conditions. They specifically mentioned how quickly TJI's fail in a fire compared to dimensional lumber. The reason is that dimensional lumber develops char in a fire and the char acts as an insulater; because the dimensional lumber is thicker, it takes longer to get to the point of failure.
All that said, I agree that dimensional lumber certainly isn't what it used to be. It doesn't suprise me at all that design values are being reduced. But then I have never stretched out dimensional lumber right to it's limit.
Bruce
Bruce H is offline   Reply With Quote
home values pooky The Mud Box 16 06-14-2009 12:42 PM
Falsely suggesting that Obama proposed taxing small businesses' revenue Jagger The Mud Box 85 03-03-2009 03:19 PM
Critique a proposed shower wall construction method for tile Uga72 Tile Forum/Advice Board 3 05-15-2008 05:01 PM
Collector car values? bljack The Mud Box 22 12-28-2007 02:05 PM
Thinsetting to southern yellow pine matman Professionals' Hangout 19 12-07-2007 05:03 PM
