03-06-2011, 10:10 AM
David
stone sealing question
I've just put down a flagstone floor on my porch slab and want to seal it.
I have a couple of products i have test on a piece of flagstone.
I have the glaze and seal natural sealer and a porduct from dupont that is basicly the same stuff.
The problem I have with these two products is they don't warm up the appearance of the stone at all.
I would like the stone warmed up just a bit.
From what I understand of these products is that they are water based + silicone based and once i put them down nothing will stick to them and you are stuck with them.
I would like a sealer that is oil based or not silicone that gives the stone a little warmth.
Is there a sealer that will give me just a bit of warmth?
I want to get this right.
David or popawheelie
03-06-2011, 10:32 AM
Senior Contributor
Look for a sealent that "enhances" the surface look. There are a few to choose from depending where you can shop. Stay with Dupont or Aqua mix if you can and avoid the stuff in the gold & green colored plastic bottles
Paul 1
03-06-2011, 10:37 AM
Independent Tile Contractor
I love Dupont StoneTech sealers.
03-06-2011, 11:41 AM
You can use the Dupont enhancer. It's at Lowes and about 30 bucks a qt.
It will darken the stone and protect it for a while. If your porch is in the sunlight through the day, it will break down the sealer faster. If not, it will last longer.
Try to stay away from a coating that will make it shiny, as they usually look pretty bad after they start to break down. Then you have to use harsh chemicals to strip before re-coating.
Do a test tile first to see if you're going to like the look. If you have an extra piece, us that for your test and let it sit for a few hours to make sure you like the look once it's dry.
03-06-2011, 12:27 PM
You will need to use the Pro series as that is rated for the outdoor use in your situation. The regular line is only rated for indoor use. I don't believe Lowe's sells the Pro line. At least mine doesn't.
03-06-2011, 07:42 PM
David
Lowes doesn't have the pro series. I went to the product website and did a product locator. Two places in town have it. I'll call Monday.
Thanks for the help. I will pick up a quart and test a pice of flagstone. Almost done with this!
03-06-2011, 09:27 PM
Not sure just what the "pro series" is that Todd's recommending, David, but if you can get the StoneTech Professional series now owned by DuPont, that's what I'd use.
03-06-2011, 10:02 PM
Actually that's what I was referring to CX.
Pedro referenced the Dupont enhancer which I assumed as Dupont StoneTech Professional Enhancer (which is only rated for indoor use)
So I was referring to Dupont StoneTech Professional Enhancer Pro Sealer (which is rated for outdoor use)
Ahhh.... sometimes I don't communicate well... just ask my wife.
David
pro series
The pro series and the professional is one and the same . I got what Todd was saying
I call tomorrow. Hope they have it in quarts.
03-06-2011, 10:14 PM
Not really
03-06-2011, 10:15 PM
David
I got it Todd.
Yeah, Todd, your wife tole us about that long time ago.
Now I understand what you're saying. The Enhancer is a water based product, and the Enhancer Pro is solvent based. That's their interior/exterior differentiation.
I've used the Enhancer Pro and like it well. Have never tried the water based product.
03-06-2011, 10:28 PM
I really like the Enhancer Pro too. Other than the stink!
03-07-2011, 09:31 AM
that is sandstone, get a lot of sealer.
03-07-2011, 01:59 PM
#15
For an excellent "solvent based" enhancing sealer Miracle Sealants has their Seal and Enhance product that does a great job in providing "warmth" to that stone.
Robb
Miracle Sealants Tech
"Serving the Tile, Stone and Masonry Industries for 25 Years"
www.miraclesealants.com
