Ok, ripped the subfloor out. Scabed 3 of the 5 joist with 8 ft sections of 3/4 by 7 in plywood sandwiched with an 8ft, 2 by 4, screwed in each layer. The one joist damaged by water was also scabed with plywood as well as a new 2x8 joist. A pole jack with 1x6 metal plate was placed under this damaged/new joist. (Found out this Joist was never truly supported it was boxed to the 2 surrounding joist.)
Joist are now 2x8's, 16 in on center, over a 10 ft span.
I believe I can now tile?? as soon as I fix the plumbing
Questions
I plan on using 3/4 " plywood or as close to it as I can get for the subfloor.
Then what do I use???
backerboard or plywood?
Can I screw the backerboard to the subfloor or must I use mud?
Can I simply use 1/8 or 1/4 plywood screwed into the subfloor and mud and tile over it?
Should I put down a water sealer on the backerboard or plywood before I mud and tile? What type should I use?
If I need to use backerboard what type do I use? is 1/8 " ok?
Please help.
I think I'm in over my head.
Michelle
I'm glad I opened it up but what a mess!
