Unread 02-13-2014, 09:39 PM   #4021
Welcome, Don.
If you're in the tile trades it'll help to put some information into your User Profile so folks can see who you are and what you do and where you do it and that sorta thing, eh? Might even wanna start a thread of introduction if you plan to stay with us for a while.
Unread 02-14-2014, 08:22 PM   #4022
DOnNyRoc
Evan. How would you of repaired it differently?
Don
DOnNyRoc is offline   Reply With Quote
Unread 02-14-2014, 08:53 PM   #4023
evan1968
Not So Senior Contributor
evan1968's Avatar
I would have walked away and not did it.
When that shower leaks the last guy that touched it gets the blame.
Ps...see the request from CX. Im assuming your in the Rochester area from your username?
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 02-14-2014, 11:17 PM   #4024
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
I don't recall making any negative comments, but since you asked I would not have run the greenboard back into the tiled area.
Originally Posted by Don
Most you guys don't even know how to even do a mud job and don't even know what Portland slurry is. guys are screwing down cement board on wavy and uneven floors with Sheetrock screws and liquid nails and consider themselves craftsmen.
Not sure what that comment has to do with the the tub repair job.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 02-15-2014, 12:09 PM   #4025
DOnNyRoc
Evan. I understand what your saying. It was a favor my neighbor who's a close friend also. There are tenants living in there so it had to be a quick repair job for now. A gut would take a few days. The green board issue it that I couldn't extend the cement board further there would be no place to nail it. I can't place a beam there without ripping down the wall. If it ends up leaking which it will eventually from the builders crap work that's a story for another day. I'm from Staten Island ny
Don
Unread 02-15-2014, 01:51 PM   #4026
blue_can
I'm not a pro but if it were me I would have at least inspected the area behind (if necessary with an inspection camera), looked at the damage (if any) and reported it to the owner before closing it up.
I have a shower remodel thread up in the advice forum where the builder never water proofed the shower and the leaks form the corners of the tub has caused a significant portion of the floor and some of the studs to rot. I'm currently in the process of replacing the affected studs and flooring.
The neighbor of a friend of mine in SD experienced a similar thing. When the problem showed up there was a damp patch forming on the exterior of the home (here most homes have stucco as siding). When the issue was investigated it turns out that something similar to your problem had occurred - during construction a screw had nicked the water piping. It had been leaking steadily for years and by the time they discovered it it was a mess. The whole bathroom and to be demolished and reconstructed - there was mold everywhere.
In my case I have been lucky - the damage is limited and virtually no mold.
Ravin
blue_can is offline   Reply With Quote
Unread 02-18-2014, 01:14 AM   #4027
ajmelin
I'm not a pro, but something doesn't seem right with this shower
Anthony
ajmelin is offline   Reply With Quote
Unread 02-18-2014, 06:17 AM   #4028
Peerless Tile
Tile Contractor
it's called photoshop
SC Greg
Peerless Tile is offline   Reply With Quote
Unread 02-18-2014, 03:53 PM   #4029
ajmelin
Pretty sure it's not 'shopped. There are all kinds of similar pictures from the hotels near the Olympics.
Anthony
Unread 02-18-2014, 05:55 PM   #4030
evan1968
evan1968's Avatar
I second the photoshop.
Even the Russian government,who can make ICBM's but cant make a refrigerator work for more than five minutes, wouldnt do that in a shower.
BTW...they messed up the checker pattern.
Craig
Unread 02-18-2014, 07:26 PM   #4031
Peerless Tile
Tile Contractor
That's not messed up...It's a trademark!
SC Greg
Unread 02-18-2014, 11:09 PM   #4032
Proven One
mess maker
Really who the hell puts a heat register in a shower....and the soap dish seems a bit high....but I'm kinda short
Eric
Proven One is offline   Reply With Quote
Unread 02-18-2014, 11:40 PM   #4033
Eric,
We see those often in condo's and highrises as the exhaust vent for the shower / bathroom. The wind passing the building, along with the building's natural chimney effect makes for a cost free exhaust system.
Unread 02-19-2014, 12:48 AM   #4034
I'm thinking that is an AO or Dal 4 1/4" along with bullnose trim. Even the ceramic soap dish is the exact same profile we can buy in the States.
Very typical looking American bathroom, don't think that shower is in Russia.
Here is a bathroom from Sochi- the tile work looks ok
Isaac
Maui, Hawaii
Unread 02-19-2014, 06:03 AM   #4035
Peerless Tile
Tile Contractor
There's a starters tree (think drag racing) just out of the picture in front of the two heads....It helps keep the competitive juices flowing while waiting around in Sochi for your event.
SC Greg
Absolute worst tile finishing job pitterpat Professionals' Hangout 17 04-02-2007 07:12 PM
worst of the worst... botched jobs Dan O'Connor Tile Forum/Advice Board 5 02-22-2007 03:21 PM
best and worst tile saw in $300-$500 range LinLee Tile Forum/Advice Board 9 01-30-2006 01:50 AM
best and worst tile saw in $300-$500 range johnnyaico Tile Forum/Advice Board 10 01-27-2006 03:05 PM
The worst job................ opiethetileman The Mud Box 6 10-08-2004 10:48 PM
