Unread 01-20-2005, 06:20 AM   #1
John K
Shear
I see guys applying Ditra and setting tile and grouting to the base boards.
I also see guys doing the same thing with backerboards.
Which one will shear first?
John
www.precisiontilestone.com
John K is offline   Reply With Quote
Unread 01-20-2005, 07:00 AM   #2
Dave Gobis
da Man!
Dave Gobis's Avatar
Doesn't make much difference all things being equal. Shearing on floors is lateral movement in the tile installation caused by lack of movement accomodation in the tile assembly. The tile typically comes up clean and the thinset is on the substrate. I spent about a day and a half this week, literally, backing up a statement I made that even grouted into drywall you have created more than enough force to shear the floor. Uniform compressive load values of drywall are twice the shear of most popular thinsets.
Unread 01-20-2005, 07:50 PM   #3
Probably neither one would shear from the underlayment. There is a chance, though, that the compressive force would lift the installation (underlayment and all) off the subfloor. I know from bleak experience that if a tile installation is going to "tent," nothing is going to stop it.
Unread 01-20-2005, 08:05 PM   #4
Davestone
Florida Tile & Stone Man
Had people tell me it sounds like a gun going off when it jumps up off the floor.
http://Davestonestile.com
Unread 01-21-2005, 05:13 AM   #5
John K
I have seen this happen in slabs, but has anyone had experience with tile shearing off above grade floor system?
John
Unread 01-21-2005, 06:45 AM   #6
Dave Gobis
da Man!
Dave Gobis's Avatar
Yeah, 2 phone calls yesterday. One over a membrane and one over backerboard. Have seen a boatload otherwise over the years as well. Slab or suspended, it all moves, some more than others.
Unread 01-21-2005, 07:45 AM   #7
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
That would be an SLC installation done over single layer plywood Dave.
Yep yep yep,scare the begeesus out of the homeowner watching a good old war movie when it happens.Talk about virtual reality and surround sound
