Unread 12-09-2011, 01:55 PM   #1
sosugrl23
help! Dark grout with white coating
I have dark tile and grout covering about 40% of my house and there seems to be a white filmy coating on the grout. I cant get it out. I have tried everything including grout/tile cleaner we purchased from Lowes. Any help or suggestions would be great!
ali
sosugrl23 is offline   Reply With Quote
Unread 12-09-2011, 02:01 PM   #2
Davestone
Florida Tile & Stone Man
Could be a few things, we need to know more.
How old is the tile job?
Was the grout sealed how long ago,with what?
Was the tile set directly on the concrete are you in a wet area?
Could the installlers have used too much water in cleanup?
http://Davestonestile.com
Unread 12-09-2011, 07:00 PM   #3
sosugrl23
the house was built in 2003 and we have only owned it the last 2 years. I am sure it was set directly on concrete. The white coloring is not everywhere but is definitely not cleanable. We live in Oklahoma, I dont think it is to wet in this area.
ali
Unread 12-09-2011, 07:21 PM   #4
java
Hugging Trees Oct. 1st
java's Avatar
Try vinegar. About a 50/50 water mix and a scrubby.
Jason
java is offline   Reply With Quote
Unread 12-10-2011, 06:41 AM   #5
Davestone
Sounds like they've tried the weak acids Jason,they might need to go stronger to cut through either old milky sealer,or effloresence.
I would use some Sure Kleen and a stiff brush.If the cleaner does not fizz let it sit a minute,if it still doesn't fizz you need to get a citrus paint stripper and strip off the sealer.
Unread 12-10-2011, 09:10 AM   #6
doitright
doitright's Avatar
Hi Ali, Welcome!
Can you post a picture?
Was this area of discolored grout visible when you purchased the home?
How have you been maintaining the floor since you purchased your home?
John Koessler
Unread 12-20-2011, 07:24 PM   #7
Vwcrackerjack
Itile345
Vwcrackerjack's Avatar
Careful. Sure Kleen as well as other tile/grout cleaners are acidic and can actually bleach out the colors of the grout. I've seen floors with grout two and more times lighter in areas where the acid sat too long.I'd assume that if it was a sealer issue. Especially if it was built up so much it puddled at the top of the joint you should be able to put a bit of water on it and see it bead up like the wax job on a car. If it doesn't I'd suggest another issue could be the problem.
Jamey
Vwcrackerjack is offline   Reply With Quote
Unread 12-28-2011, 01:26 PM   #8
Miracle Sealants Tech
Miracle Sealants Tech's Avatar
Hello-
If one of the previously mentioned rememdies has not done what you are looking for it to accomplish, I would recommend trying either the Grout and Concrete Film Remover (GCFR - hydrochloric acid, very aggressive) or the Phosphoric Acid Cleaner (middle of the road strength) from Miracle Sealants to try and clean up your grout issue.
Be sure to dilute ANY product you may select and test the "method to the madness" in a small out of the way spot prior to using it over the entire area you intend to clean up.
Good luck.
Robb
"Serving the Tile, Stone and Masonry Industries for 25 Years"
www.miraclesealants.com
Miracle Sealants Tech is offline   Reply With Quote
Dark grout turning white, ceramic shower tiley Tile Forum/Advice Board 9 02-27-2013 12:20 PM
Dark Grout White Haze JoanieBob Tile Forum/Advice Board 3 08-29-2011 10:22 AM
White stain on dark grout lac1957 Cleaning, Restoration and Sealing 7 11-07-2009 02:13 PM
Why would grout start dark come out white? flazoom Tile Forum/Advice Board 4 11-02-2009 06:27 AM
Dark grout turning WHITE!!?!?? esc Tile Forum/Advice Board 5 12-24-2008 10:53 AM
