Unread 10-17-2019, 10:34 AM   #1
hinton308
Sealing Travertine
Getting ready to build new house that will have approx 3000 sq ft of beige travertine stone in a Versailles pattern. It will be installed over concrete slab with Ditra membrane. What is recommendation for sealing product. I have look at the 2 companies that are sponsors and not sure which of their products is best for application. Also, how often should sealer be reapplied? Is there a commercial product that may be better for this application? Any advice on grout material?
Thank you for your help
Don Hinton
Don
hinton308 is offline   Reply With Quote
Unread 10-17-2019, 12:42 PM   #2
Welcome, Don.
Best is in the eyes of the purchaser. Best stone sealing products with which I'm familiar are the StoneTech Professional products now owned by the Laticrete company. I can't testify that those products are still being made by StoneTech, but I know they were for a time after they were bought out by DuPont and then by Laticrete. I'm told now, but not necessarily reliable source, that Laticrete is now actually manufacturing the products. Perhaps Ms. Sharon will stop by and enlighten us.
If your stone is not particularly pourous, I'd recommend the StoneTech Heavy Duty Sealer. If it's particularly pourous, as I'm told some Travertine is, I would recommend the StoneTech Bulletproof.
That presumes both are the same products they were when StoneTech manufactured them.
Unread 10-18-2019, 05:01 PM   #3
MAPEI - Technical Service
Company Representative
Hey Don,
Welcome to the forum!
Travertine is a pretty easy to get along with type of stone in regard to sealing. There aren’t many products out there that wont work on travertine.
We have a water based penetrating sealer called UltraCare Penetrating Plus Stone Tile & Grout Sealer that would work well for you from the sounds of it.
With any sealer make sure you work in small areas, apply enough to wet the tile so it can absorb as much as it will take, and be sure to buff off excess promptly to avoid white residues. Of course follow the installation instructions of the sealer selected closely, as they will all vary a bit from product-to product and company to-company.
Holden
http://www.mapei.com/US-EN/
Unread 10-20-2019, 02:30 PM   #4
Sharon @ LATICRETE
Sharon @ LATICRETE's Avatar
STONETECH products are manufactured by LATICRETE and have been since the purchase from Dupont in 2014.
If honed we'd suggest STONETECH Bulletproof Sealer. If polished use the STONETECH Heavy Duty Sealer.
Here are some helpful links:
https://cdn.laticrete.com/~/media/su...18CymId-petuOg
https://cdn.laticrete.com/~/media/su...rgpF80oqWZGK5c
Sharon@LATICRETE
Sharon @ LATICRETE is offline   Reply With Quote
Sealing travertine azhalifax Tile Forum/Advice Board 4 11-24-2017 08:05 AM
sealing travertine figaro Cleaning, Restoration and Sealing 6 10-18-2012 11:42 AM
Help W/sealing Travertine yulonda Tile Forum/Advice Board 1 06-12-2006 11:31 PM
Sealing travertine Steve Edmonds Cleaning, Restoration and Sealing 1 05-15-2006 04:36 PM
sealing travertine churchcamp Cleaning, Restoration and Sealing 2 11-18-2004 11:40 AM
