Unread 06-24-2019, 11:02 AM   #1
Elkski
Elkski's Avatar
Taming the beast! The monster that is Flexcolor 3D Mapei
I read where another poster refered to flexcolor 3D as "a a different kind of beast". I agree so much. It is like the beauty and the beast. on flat tile maybe this is not that big of deal but when you are talkin about wavy Subway class this beauty turns into an ugly beast. my first sample board was an utter failure in trying to remove the excess and it was less than one square foot in size. my second attempt was a little better and included a little patch where I taped each tile edge. My fallback was ultracolor plus fa White, but the test board results said I must go with flexcolor 3D. So two hours of taping 25 of 110 tiles. This is my initial report and results.
Teddy
Unread 06-24-2019, 11:06 AM   #2
Elkski
Elkski's Avatar
I can only seen to upload 3 pics at one time?
I let certain areas dry, wiping them down the best I can but trying to leave the joints very full. There are many different dryness steps where you need to wipe and shape with one step near the end getting rid of the protruding sandpaper like big glass beads.
Teddy
Unread 06-24-2019, 11:10 AM   #3
Elkski
Elkski's Avatar
More.
Teddy
Unread 06-24-2019, 11:45 AM   #4
Elkski
Elkski's Avatar
It does sparkle and shine.
Teddy
Unread 06-27-2019, 06:51 AM   #5
Metropolitan Ceramics
I was at MAPEI when 3D was being developed. Some rubber cement on the tile faces can also be used instead of tape when you're dealing with 3D surfaces like this glass or many types of stone. A grout bag instead of a float can also help. The less you get on the surface, the less you have to remove. When it does come time to remove the haze, a citrus cleaner designed for adhesives (Goof Off, Good Gone, etc) does a much better job than water. Great looking install!
Dan Marvin - VP of Operations
www.ironrock.com
Unread 06-27-2019, 07:10 AM   #6
MAPEI - Technical Service
Company Representative
That final product looks fantastic Teddy!
With some of the more ambitious tiles out in the world today, it does certainly take some creativity during the installation process to make everything look great and save yourself from headaches. I'm glad you found a system to cut those headaches off at the pass.
Again; great work sir!
Holden
http://www.mapei.com/US-EN/
Unread 06-27-2019, 07:18 AM   #7
Elkski
Elkski's Avatar
Thanks guys. It is a great look.
Holden,. I was disappointed to find out I could not use Flexcolor 3D in my steam shower or near a fireplace. I'm the kind of guy who likes to know the reason behind directions and rules. can you tell us why a worm location is a problem for flexcolor 3D?
Teddy
Unread 06-27-2019, 07:37 AM   #8
speed51133
FYI, Goof Off is NOT a citrus cleaner. It used to by Xylene until California had a problem with it few years ago. It is now essentially acetone. It will dissolve plastics, is flammable, and toxic.
Not saying don't use it, but I would not apply it as freely or liberally as I would a citrus cleaner.
speed51133 is online now   Reply With Quote
Unread 06-27-2019, 09:35 AM   #9
My container of Goof Off says it contains "benzyl alcohol, ethanol and glycol ethers."
Unread 06-27-2019, 09:43 AM   #10
speed51133
how old is it? what "model" is it? Aerosol?
Just google search "what is goof off made of". It is hard to get a real, current answer. This database is ran by the US Dept. of health and Human services, which I presume is accurate as it was updated in 2019. It lists it as 90-95% xylene, which is interesting. I read on many other websites that it was reformulated for California. Maybe they sell a specific SKU just for California??? At any rate, I would not use it interchangeably with Goo Gone, which makes MANY MANY different models and formulas, some of which use citrus. Xylene though, is nasty shit.
https://hpd.nlm.nih.gov/cgi-bin/hous...nds&id=7015003
Methoxydiglycol 000111-77-3 1.0-5.0
Xylene (mixed isomers) 001330-20-7 90-95
Unread 06-27-2019, 09:53 AM   #11
Perhaps a few months old, Mike. Spray bottle.
Unread 06-27-2019, 10:20 AM   #12
speed51133
the spray actually has a unique formula. Looks safer. ANYWAYS, my point was Goof Off and Goo Gone are not similar and Good Off is not citrus. I know people think of citrus cleaners as safe and only as harsh as lemon juice. Below is what the spray version is (at least in 2015). At least you are not using xylene . I have a pregnant wife in the home, xylene is a concern for me:
https://www.whatsinproducts.com//bra...w_msds/1/17123
100-51-6 Benzenemethanol {Benzyl alcohol} <10.0 % DN3150000
2568-90-3 1,1'-[Methylenebis(oxy)]dibutane <10.0 % NA
27177-77-1 Benzenesulfonic acid, dodecyl-, potassium salt <10.0 % DB6820000
112-34-5 Diethylene glycol monobutyl ether
{2-(2-Butoxyethoxy)ethanol {(a glycol ether)}
< 5.0 % KJ9100000
Additional Chemical Specific percentage of composition is being withheld as a trade secret.
Information
Unread 06-27-2019, 12:10 PM   #13
Elkski
Elkski's Avatar
I thought all those Goo b gone cleaners were safe and nearly the same thing. this grout is kind of like a glue so probably do pecan wood work but normally the finger now or a razor blade works pretty good. If it's not too hard a white glass ok scrubby with water works with elbow grease.
Teddy
Unread 06-27-2019, 04:06 PM   #14
Gusdog
I just did a glass backsplash with the Flexcolor 3D. We love the results but I found we could only do about 2 to 3 sq. ft. before stopping to clean. By the end of the backsplash I had a fairly good system worked out but I probably will not use it again unless the project is very small.
John
John
Gusdog is offline   Reply With Quote
Unread 06-28-2019, 06:00 AM   #15
Elkski
Elkski's Avatar
John, What size tiles in the 2-3 sq ft? Mine were 3x12 so in 1 sq ft that's 7 linear feet of lines. With this time consuming tape method I didn't have to spend to much time on clean up. More just wipe until joints looked good and no deep puddles next to the lines. With the waves I couldn't help but leave deep puddles. A few minutes later ,when it had a non tacky skin, I could peel off the tape and then push it around and Pat down any lippage. A bit later I washed it to knock off high spots and the glass beads. I swear I was chewing on glass beads that night. ??? Funny a few days after I had a bad dream where I had big chunks of glass in my mouth.
Teddy
Last edited by Elkski; 06-28-2019 at 06:01 AM. Reason: And I rarely remember a dream
Mapei Flexcolor CQ nelsonkoehn Professionals' Hangout 423 04-01-2019 09:00 AM
Mapei Flexcolor 3D MudMaker Professionals' Hangout 46 08-01-2018 07:30 AM
Mapei flexcolor vs keracolor Dfletch1 Tile Forum/Advice Board 1 01-26-2018 01:16 PM
Taming the big green monster master bathroom Mooses Tile Forum/Advice Board 8 04-06-2013 07:09 PM
