Unread 08-12-2015, 08:38 PM   #1
NEPA Remodeling
Custom Home Remodeling
Leveling Shower Ceiling
I'm doing a 36x52 Kerdi shower with ceramic tile on the ceiling. The ceiling line along the 52" wall is about 1/2" out of level. This will result in an unappealing taper on the final course of 1" subway tile on the wall.
There is already Sheetrock on the ceiling in this area. Can float/level the ceiling either before or after the Kerdi membrane, or must I pull the ceiling, shim it, and replace it?
How have you folks handled this?
Phil Cavanagh
Kitchen & Bathroom Remodeling Scranton PA
NEPA Remodeling is offline   Reply With Quote
Unread 08-12-2015, 09:41 PM   #2
Use self-leveling compound.
Is the shower completely enclosed, or are one or two sides open to the rest of the ceiling in the bathroom?
Unread 08-12-2015, 11:18 PM   #3
PetrH
I would absolutely open it up. Takes about 10 minutes to unscrew the sheetrock, 15 minutes to screw on some shims or sister joists. Let's say 1hr max start to finish. Way less hassle than trying to float it somehow and spend an extra day for things to dry.
Petr
Unread 08-12-2015, 11:57 PM   #4
bc brick john
bc brick john's Avatar
lucky you
have a buddy whos old timer is way way out of wack
in fact going to take some pics and post in a new thread ......
going to make you smile
John
Senior Lecturer in Brickwork Masonry
Training instructor/Assessor
brick mason & tile setting
www.stonetilegibsons.ca (under construction)
bc brick john is offline   Reply With Quote
Unread 08-13-2015, 01:36 AM   #5
ded dux
ded dux's Avatar
I second the pull it comment. Less time to do it right, and you'll sleep better.
Don
ded dux is offline   Reply With Quote
Unread 08-13-2015, 02:57 AM   #6
Carter907
If it's not enclosed, I would pull it and redo it. If it is enclosed then the slope is necessary and should maybe be more than 1/2". If it must be flat, floating it would be about a complete nightmare!
Carter
Carter907 is offline   Reply With Quote
Unread 08-13-2015, 05:21 AM   #7
NEPA Remodeling
I didn't hang the rock, The drywall is fully finished/painted and was glued
The ceiling opens up to one side of the room.
It's primarily 1 corner of the ceiling that is up above the rest. That's why floating out came to mind. Pulling down the ceiling would probably be an equal/bigger pita.
I've floated ceilings with joint compound many times, to get a better crown moulding install, wasn't that bad.
Phil Cavanagh
Unread 08-13-2015, 10:35 AM   #8
The reason I asked if it was enclosed was to see if you could pull and replace it without affecting the ceiling in the rest of the room. Can you do so and still maintain a flat ceiling throughout, or is going to require pulling some of the ceiling into the rest of the bathroom?
Unread 08-13-2015, 06:54 PM   #9
Carter907
I guess I'm just lazy, I hate floating anything but the floor!i had to triple float a shower a couple weeks ago. I didn't do the rock, the guys who built the wall and rocked it didn't have a clue. I couldn't talk the people into a full redo, so I had to float out 3 walls. One spot was about a 7/8" dip in 2 feet. And I still managed to get it flat enough , as long as you don't look at it...
Carter
Unread 08-13-2015, 07:27 PM   #10
NEPA Remodeling
This ceiling had a few high joist above the cabinets, we just make the ceiling work with the crown. The framing flaws disappeared.
Cutting out part of the ceiling to flatten it will likely create a ridge at the seam, which would also need floated. Drywall is flexible to a point, but not so much over a short span. I figured I can taper mud just as easily as trying to align two pieces of rock.
If you were to float it, would you do it under or over the Kerdi? Not so much worried about time for curing. There's other areas I can work while it cures.
Phil Cavanagh
Unread 08-14-2015, 12:16 AM   #11
PetrH
If I were to float it, I'd likely screw on a strip of 1/2" CBu in the offending corner, some scraps of 1/4" further out to mostly fill the hollow and then float with thinset. I don't worry about perfection, if you get back to it the next morning it's still easy to shape with a scraper or even a straight edge.
Petr
Leveling Shower Ceiling Sammy DYI Tile Forum/Advice Board 3 06-07-2009 05:36 PM
Shower Ceiling MARK T V Tile Forum/Advice Board 10 07-27-2007 11:07 AM
Call all Leveling Gurus - Self Leveling Compounds chefwong Tile Forum/Advice Board 7 07-06-2006 05:39 PM
My Shower Ceiling MarcSavage Tile Forum/Advice Board 3 09-14-2005 09:55 PM
shower ceiling Lunatic Tile Forum/Advice Board 31 10-14-2002 09:43 PM
