Unread 02-28-2015, 05:07 PM   #1
bc brick john
bc brick john's Avatar
stone issue in shower
Hi folks
i done an install in 09
and had a call back to try sort out the issue with it.
it looks like the water/minerals has been causing the stone to break down and
appear really faded and course to the touch
on the outside of the shower its OK its in the wet area
the stone was
Valverde Azul honed 16 X16
you can see the difference on the threshold step
and where its been attacking the fill in the honed stone
any remedies one can suggest
John
Senior Lecturer in Brickwork Masonry
Training instructor/Assessor
brick mason & tile setting
www.stonetilegibsons.ca (under construction)
bc brick john is offline   Reply With Quote
Unread 02-28-2015, 07:16 PM   #2
I can't help with the issue, John, but I'll move you over here where more of the stoners hang out.
Unread 02-28-2015, 09:29 PM   #3
tileman85
Is this happening at the same hight on all the walls in the shower?
Preston
tileman85 is offline   Reply With Quote
Unread 02-28-2015, 09:49 PM   #4
Was it a mudded curb?
Unread 02-28-2015, 09:56 PM   #5
Hi John,
Looks almost like soap scup or hard water build-up. But with the unfocused picher, it's kinna hard to see. Any chance of a more clearly focused picher?
Unread 03-01-2015, 11:52 AM   #6
bc brick john
few more pics
sure does look like the water and soaps have eaten into this stone
it was sealed with sealers choice if i remember
its worse around the bottom. shower pan tile is a dal tile and not really affected.
its a mud pan on a rubber liner
kerb is wood framed wrapped over liner
upper floor on timber framed house with radiant heat floors // 2" pour lwt concrete
don't think any where in the shower pan area
densheild with redguard on top
as if you look at the curb threshold it still half shinny as installed/outside of the shower cubicle but where the water has hit it looks and feels course and pitted
John
Unread 03-01-2015, 06:47 PM   #7
tileman85
It looks like water is wicking up from the floor. Your first course of tile isnt in the mud bed? Also, cracks in the grout or tile can let water in behind the tile? Sometimes it builds up and starts leaching out, if it can't drain out fast enough. I seen this happen from a slab shower bench. No one caulked the gap under the over hang and water would go down the face and fill up around the base of the shower up to the curb and run outside of the shower.
Preston
Unread 03-02-2015, 10:51 AM   #8
Stone Dude
That is Jura Grey limestone. Soft and fairly porous, but dense for a limestone. Its not uncommon to see some signs of moisture in the stone when there is no problem with the pan, but there shouldn't be much.
These photos as kind of vague. Some shots that show the entire floor/bottom of the walls would help
The dull white are looks like the outside pf the door on rop of the curb? Is so, it just looks like standing water has taken its toll. It needs to be refinished
Cameron DeMille
SFA, MIA
MillestoneMarble.com
2nd Floor Wood Joist Deflection issue for Stone Installation ProTech Tile Restoration Tile Forum/Advice Board 6 09-23-2013 06:19 PM
Stone on deck -- structural issue Registered Guest Tile Forum/Advice Board 3 06-29-2009 12:31 PM
Stone tiling issue Gerry in Belle River Tile Forum/Advice Board 4 11-15-2008 03:49 PM
Stone World Jan 08 Issue JTG Professionals' Hangout 0 01-16-2008 04:16 PM
Stone issue wesley foote Tile Forum/Advice Board 1 06-11-2006 08:46 PM
