Unread 07-21-2013, 10:43 AM   #1
Bubba1855
white specs in dark grout
Contractor just finished putting down porcelain tile on outdoor patio. Used CBP, sanded grout/polyblend. It's a dark color...color name is 'new taupe'.
The tile is a slate color, we wanted a darker grout. Tile went down fine, the grouting went fine...just the color we wanted. Contractor recommended 'sealing' the grout. He did our baths last year (grout and tile are 'light' colors). I did the sealing with CBP Choice Gold...no problems. Looks fine.
However, when I applied the Choice Gold we ended up with the infamous 'white' haze. Called CBP and they said 'vinegar' and/or their 'Nano Scrub' product. I went straight to their 'Nano' product. Followed the directions to a 'T'...It appears that the white haze caused by excess sealer is gone...but all of the sealed grout has white specs in it...making the grout color look almost white. No amount of scrubbing will get it off. I used, by hand, one of those carbide grout removal blades in a small area to see how far down it goes...It looks like it goes as deep as the 'Choice Gold' penetrated.
If we have to remove the grout and start over, so be it. If I remove the grout and re-grout I sure don't want to use 'Choice Gold' again...What should I use...and yes whatever you recommend I'll only put down on a small sample before proceeding...
Thanks in advance for your comments.
Bill
Bill
Bubba1855 is offline   Reply With Quote
Unread 07-21-2013, 11:55 AM   #2
Cain
Cain
I am going to guess that the sealer is not the culprit here.
Polyblend is a low end cement based grout. In an exterior application moisture in the air can cause some shading issues.
I would recommend an epoxy or urethane grout and then you wont have to seal.
Sealers choice is a good sealer, but outside I would use dry treat
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is online now   Reply With Quote
Unread 07-21-2013, 12:19 PM   #3
Ken
welchtile.com
I would have to disagree with Cain's suggestion of using an epoxy grout on slate. As a rule of thumb, I stay away from epoxy grout on a natural stone. You're asking for problems with the results of the product, in my opinion. I know that a lot of manufactures say their epoxy is safe for stone material, but I stay away from epoxy on stone..
For your situation, I would recommend that you remove all of the grout and use a highly pigmented cementitious grout like LATICRETE PermaColor or TEC PowerGrout.
Ken
Ken is offline   Reply With Quote
Unread 07-21-2013, 12:31 PM   #4
Bubba1855
Just to clear up something that 'Ken' said. The tile is not slate, it's porcelain tile, a slate color...
Bill
Unread 07-21-2013, 12:33 PM   #5
Ken
welchtile.com
My bad.. I did read that completely wrong.
Now my whole opinion changes... Rip out the grout and use an epoxy grout.
Ken
Unread 07-21-2013, 12:40 PM   #6
Cain
Cain
So you do agree with me huh Ken?
Cain Curtis
A Tile Experience
Unread 07-21-2013, 12:42 PM   #7
Ken
welchtile.com
Yeah.. For some reason I totally thought it was Slate.. I'm sorry Cain. :\
Ken
Unread 07-21-2013, 02:02 PM   #8
Davestone
Florida Tile & Stone Man
I wouldn't do either one,sorry.
I would use a color sealant so you don't have to remove the grout at all.I would first clean with sulfamic acid crystals,and a grout brush.This may just remove a lot of the white specs of sealer and solve your problem.At least it will open the pores of the grout so the colorant will adhere well.
http://Davestonestile.com
Unread 07-22-2013, 01:30 AM   #9
doitright
doitright's Avatar
Hi Bill, Welcome!
To me it sounds like you may still have some residue from the Nano Scrub, not a sealer issue. If that's the case, you may just need to pressure wash your grout. Since it's fresh grout, I would keep the pressure down as not to blow out your grout.
If that doesn't work, I'm with Dave on using the grout colorant.
John Koessler
help! Dark grout with white coating sosugrl23 Cleaning, Restoration and Sealing 7 12-28-2011 01:26 PM
Dark Grout White Haze JoanieBob Tile Forum/Advice Board 3 08-29-2011 10:22 AM
White stain on dark grout lac1957 Cleaning, Restoration and Sealing 7 11-07-2009 02:13 PM
Why would grout start dark come out white? flazoom Tile Forum/Advice Board 4 11-02-2009 06:27 AM
Dark grout turning WHITE!!?!?? esc Tile Forum/Advice Board 5 12-24-2008 10:53 AM
