Unread 05-22-2017, 08:43 AM   #16
Dave Gobis
da Man!
Dave Gobis's Avatar
Well, for me, guys who mix and/or self engineer products makes for good business. Reverse engineering for forensic analysis is always a big invoice. Just had one in Edmonton AB and it was the second time it didn't work. I agree, you never know till you try but on that project they wanted to stick someone else with the bill. Each to their own as long as they own it.
Unread 05-23-2017, 04:08 AM   #17
eurob
Not...Sure
I agree Dave. Lots of " chemists " out there ....... And it is nothing compare to -- mixing -- adding a known ingridient vs. Unknown ones from different products & mfgs.
Roberto
Unread 05-26-2017, 01:46 PM   #18
Steve Taylor
Today there are a lot of choices when it comes to ceramic tile mortars. If one does not exactly give you the properties you want, consult the manufacturer's technical service staff and they probably have another product that will give you what you want. This will keep you in the clear with issues with the quality of the mortar.
Steve
Retired Tile Industry Chemist
Steve Taylor is offline   Reply With Quote
Unread 05-29-2017, 10:45 AM   #19
Good Morning Flooring
Journeyman
For anyone interested in this product, I did end up switching. I actually do like x5 slightly better, but not enough to go to a different distributor, and yes to those who asked, I'm using pac rim. Magna flex pro is very very similar to x5, as long as you follow the slaking directions, if you don't slake it properly it will fire off pretty quick. I found it does skim over a bit faster, so I spread about 15% less mortar at a time when doing small tiles. Big tiles I normally only spread enough for 1 tile at a time anyways, so no difference there. Worth trying as an x5 alternative
Steven
Good Morning Flooring is offline   Reply With Quote
Unread 05-29-2017, 03:58 PM   #20
bc brick john
bc brick john's Avatar
and as are friends with the know?
both chemical set mortars.
as both can be used to set Schulter and other stuff.
i just gave a recommendation just to use it up rather than it be thrown in a land fill
bit like some of the guys who mix and match with sanded and non sanded...
but thats not me .....
oh more
John
Senior Lecturer in Brickwork Masonry
Training instructor/Assessor
brick mason & tile setting
www.stonetilegibsons.ca (under construction)
bc brick john is offline   Reply With Quote
Unread 05-29-2017, 07:57 PM   #21
eurob
Not...Sure
Originally Posted by bc brick john
not recommended but makes a nice mix is 2/3 thirds ardex X5 to a 1/3 magnaflex.
The right recommendation would be to use them without mixing them . No need to throw one of them in a land fill , just mix one and use , then mix the other one and use .
The -- not to do -- is to mix both and use the mixture for tile setting.
But let's say John is right , is there any chemical component(s) which interfere with other ones or , is there any chemical --both chemical mortars -- negative or non beneficial reaction ?
Roberto
Unread 05-30-2017, 03:36 PM   #22
bc brick john
Thanks Rob
as where not told whats in our thinsets
we dont know if we can mix them or not ?
its best practice not to
especially differing brands who knows we end up
or creating a nice mix that we all like to use.....
John
Unread 06-01-2017, 03:44 AM   #23
eurob
Not...Sure
Have left overs of 1-1-6 and UF2 ........ Going to mix them 'till I get a likeable mix and use it ....... Not recommended , but I may like it
Roberto
Tub flex GaetanoL Tile Forum/Advice Board 3 02-06-2016 03:20 PM
TEC 1 Flex INtilesetter Professionals' Hangout 13 02-23-2006 06:34 PM
TEC 1 Flex Crack-Isolation Mortar charles2 Tile Forum/Advice Board 15 01-03-2006 11:25 AM
1 flex Everything_In_Between Professionals' Hangout 10 05-26-2004 05:16 PM
Tec Full Flex Mortar And Ditra oggiem Tile Forum/Advice Board 15 02-25-2004 03:42 AM
