Unread 06-26-2022, 09:16 AM   #1
classic_erik
White Grout Haze on Noir Honed Travertine
Hello All - First timer here! Hoping to get some quick guidance on removing what I believe is white grout haze on my new noir honed travertine floor. I'm new to the tile game so I could be completely wrong.
The travertine was not sealed before installation. The shower head was leaking a good clip for 2 weeks down the shower wall unbeknownst to me and left a hazy stain on the floor. I believe it is from the white grout from the shower walls but I could be wrong. The walls are a porcelain tile so we obviously didn't seal or treat the surface in any way post installation.
I've tried a few PH neutral cleaners including Miracle Sealants Heavy Duty Cleaner (Acid Substitute) and nothing seems to help. Here are some photos. You can see the edge of the blurry area vs nice looking stone up close. Any suggestions to remove this without damaging the stone?
Erik
classic_erik is offline   Reply With Quote
Unread 06-26-2022, 10:05 AM   #2
Welcome, Eric.
What grout did you use? Be very specific.
Unread 06-26-2022, 10:32 AM   #3
classic_erik
MAPEI Keracolor Unsanded 10lb in Avalanche.
Erik
Unread 06-29-2022, 04:16 PM   #4
Jason@mapei
Jason Cantin Mapei Technical rep
Jason@mapei's Avatar
Here is a link to Mapei grout troubleshooting guide.
I hope this helps
https://cdnmedia.mapei.com/docs/libr...rsn=376da9bf_4
Jason
Jason@mapei is offline   Reply With Quote
Unread 06-29-2022, 08:09 PM   #5
let us know if you find the answer to your question in that Troubleshooting Guide, Erik.
Thanks, Jason. Probably should be in our Liberry.
Unread 06-30-2022, 06:20 PM   #6
smifwal
I would go at it with a dry microfiber cloth or a magic eraser or maybe a damp one and then a dry one
Unread 07-09-2022, 11:48 AM   #7
classic_erik
Thanks all but there is nothing in the MAPEI troubleshooting guide that covers the removal of grout haze. This also isn’t very specific to my use case with the honed travertine.
Erik
Unread 07-15-2022, 09:05 AM   #8
Jason@mapei
Grout haze remained on the surface of the tile. Use MAPEI’s UltraCareTM Cement Grout Haze Remover (see the addendum
“UltraCare Quick-reference guide”).
Grout haze was left on the tile surface due to grouting
being performed without wetting down the tiles first.
Tile should be moistened to minimize grout haze. Use MAPEI’s UltraCare
Cement Grout Haze Remover to remove cement grout haze (see the
addendum “UltraCare Quick-reference guide”).
Jason
Unread 07-16-2022, 06:35 AM   #9
classic_erik
Sorry Jason but that is an acidic cleaner. I appreciate you trying to help but I need something PH neutral for the travertine.
Erik
Removing white haze from charcoal grout and gray haze from white stones jaydub_atl Cleaning, Restoration and Sealing 9 06-09-2016 11:39 AM
white haze on tan grout emaxxman Cleaning, Restoration and Sealing 21 05-05-2014 06:24 PM
Dark Grout White Haze JoanieBob Tile Forum/Advice Board 3 08-29-2011 10:22 AM
White haze on grout jimbo22s Cleaning, Restoration and Sealing 16 12-07-2009 11:04 PM
White Grout Haze sbenton Tile Forum/Advice Board 15 09-12-2007 05:25 AM
