Unread 01-04-2017, 11:36 AM   #1
cpad007
hack of some trades
cpad007's Avatar
Deck mud to level/support tub?
I'm planning to use Mapei's 4 to 1 as a bedding mixture to embed/support my acrylic American Standard tub (click to see it). I will easily meet the minimum requirements for deck mud thickness.
Do I need a membrane (tar paper, plastic sheet, etc.) to keep the mud off the plywood? Or do I just plop the deck mud right on the plywood?
Or should I use something else other than deck mud?
Chris
DIYer-us Extrem-us Non-Pro-us
Chris' Orange Tile Project
cpad007 is offline   Reply With Quote
Unread 01-04-2017, 11:48 AM   #2
That's not what you wanna use, Chris. In pre-bagged material you'll want a Mason's Mix or Mortar Mix for the purpose. You want something that your tub can moosh (sorry, technical term) into and deck mud, anybody's deck mud, won't do that.
I'd always recommend a cleavage membrane of some sort under the mud in that application. Some folks like also to put very thin (1.5 mill or so) polyethylene sheeting on top of the mud before setting the tub so's to keep the mud from actually adhering to the tub to facilitate future removal.
Unread 01-04-2017, 11:55 AM   #3
JET
Cx, just clarifying, so 'moosh' is a technical term used by professionals, and 'smoosh' would be the term the rest of us should use? I wouldn't want to get into trouble with any professional associations, or anything like that.
John
JET is offline   Reply With Quote
Unread 01-04-2017, 12:00 PM   #4
cpad007
hack of some trades
cpad007's Avatar
Thanks, CX.
I'll use your moosh-able advice and go with the mortar/mason mix and maybe I'll do the next guy a solid (could be ME!) and add the saran wrap to the top of the mix to facilitate future removal.
Chris
Unread 01-05-2017, 06:51 PM   #5
Mathelo
Lurking here ...
So something like QUIKRETE 60-lb Gray Type-N Mortar Mix?
https://www.lowes.com/pd/QUIKRETE-60...ar-Mix/3006083
Louis
Mathelo is offline   Reply With Quote
Unread 01-05-2017, 07:43 PM   #6
Dave Gobis
da Man!
Dave Gobis's Avatar
Think the official term is snotty.
Unread 01-05-2017, 08:46 PM   #7
Louis, I think that mud is fine. I also add lath over the tar paper or plastic to help the mud stay in place.
Unread 01-06-2017, 12:19 AM   #8
cpad007
hack of some trades
cpad007's Avatar
Good idea, Davy. I was kinda wondering how to keep the mud from MOOSHING all over the place (down the drain hole and out the front of the tub apron, etc.) and thought maybe to screw down a wooden frame that would clear the tub bottom but the lath ought to work, too.
Chris
Undermount tub - minimum stone deck support RKenshin5 Tile Forum/Advice Board 14 06-04-2016 12:29 PM
Second Level Deck CoastalCustom Tile Forum/Advice Board 5 06-25-2012 05:27 PM
Tile deck with support posts for roof trellice? JSY Tile Forum/Advice Board 16 11-10-2007 09:10 AM
Floor level problem near the support. scorleo Tile Forum/Advice Board 4 05-03-2006 09:47 AM
renata deck level renataleo Tile Forum/Advice Board 2 08-04-2005 05:36 AM
