Unread 05-16-2016, 09:39 PM   #1
luciphil
Boulder DIYer
oxyclean solution spilled on kentucky blue rock, oh my!
An approximately 10 parts water to 1 part oxyclean that was used on some upholstered furniture on the deck was subsequently spilled on our heated stone floors of 3/4" Kentucky blue rock (a slate I would guess?) in the kitchen near the stove. It was immediately cleaned up with soap and water but still there are spots that are clearly lighter than adjacent areas. One friend suggested that since other slabs of stone other than the kitchen are clearly lighter in color along with about 2" under the toe kickboard area under our cabinets, perhaps the oxyclean solution merely gave a deep clean to an area of stone deeply in need considering we cook in there and walk around, let dogs in, etc. So, do I throw some bacon grease down and saw dust and walk around barefoot for a year and let it get back to the same color or try and do some testing with oxyclean and "strip" the whole kitchen area and reseal (which hasn't been done since we moved in 4 years ago). Lots of threads on oxyclean but could not find an oxyclean created stain so my apologies if this has already been addressed.
Phillip
luciphil is offline   Reply With Quote
Unread 05-17-2016, 05:23 AM   #2
fhueston
Oxyclean is nothing more than hydrogen peroxide. I doubt it would leave a stain. It sounds like the stone has been cleaned with it. You can clean the entire floor or try a color enhancer on the spot to darken it.
Fred
fhueston is offline   Reply With Quote
Unread 05-17-2016, 08:22 AM   #3
kathmorgan12
Agree that you should try color enhancer. The stain might not be remove even using oxyclean so better try to cheat it. But if you still want to try oxyclean better do I might be wrong on what I said.
Kath
kathmorgan12 is offline   Reply With Quote
Unread 05-19-2016, 01:01 PM   #4
stu rosen
Oxy clean is sodium percarbonate-oxygen bleach-
I agree with Fred-clean the whole floor-it will look great-
Stu
www.stoneshine.com
stu rosen is offline   Reply With Quote
River Rock and Blue Grout l_bones Tile Forum/Advice Board 3 06-06-2011 01:48 PM
Kentucky? HS345 Professionals' Hangout 20 12-03-2010 07:16 PM
Greetings from Kentucky BluegrassFlooring Professionals' Hangout 21 07-13-2010 04:42 AM
Kentucky Derby flatfloor The Mud Box 9 05-14-2004 06:44 PM
