Unread 03-14-2022, 07:54 AM   #31
Jason@mapei
Jason@mapei's Avatar
grouting moisture sensitive stone
here is an option
https://cdnmedia.mapei.com/docs/libr...sn=dd2bc862_18
Jason
Unread 03-14-2022, 01:52 PM   #32
Thanks, Jason, but 6 sided sealing isn't an option - tile is already installed. Fortunately my test area is under the vanity.
Given how little moisture this marble absorbs on the face I'm surprised the CQ is leaving them cloudy.
Unread 03-14-2022, 06:04 PM   #33
Jason@mapei
I would suggest grout release.
Jason
Unread 03-15-2022, 08:55 AM   #34
Thanks again, Jason, I feel like I'm going to have to try both. From what I've read, grout release is easily water soluble, I'm a little concerned that the moisture in the grout will remove the release as the grout is being applied.
Can you recommend which Mapei products to look for? I don't think I want an enhancing sealer.
Unread 03-15-2022, 02:50 PM   #35
Jason@mapei
Please follow all instructions on the product and our TDS.
Grout release:
https://cdnmedia.mapei.com/docs/libr...rsn=a0afcc57_0
For sealing:
https://cdnmedia.mapei.com/docs/libr...rsn=e155c020_0
Jason
Unread 04-21-2022, 09:25 AM   #36
Still plugging along. Ended up sealing the marble with Aqua Mix Sealer's Choice Gold which did not change the color at all, then grouted the floor with Ultracolor Plus FA. Pretty easy stuff to work with but sets fast and pot life is short. My work pace is snail slow so had to mix multiple small batches.
Didn't intend to install the vanity until after tiling was finished but, because of the vanity top has so little over-hang on the ends, I couldn't pull it away from the side and back wall to get the baseboard tile behind it so the tile will have to abut the vanity skirt. Not ideal, but oh well. Used the same 4X8 inch marble for the baseboard, capped with a mostly white marble half-round pencil, only one of which I broke. Will use the same pencil vertically to finish the ends of the wall tile.
I am hoping to re-use a now 15 year old Toto Aquia 1 dual flush toilet that came out of the master bath during demo. The bowl has a rear exit horn, and uses a special trap way that mounts on the floor, seals to the closet flange with a typical wax ring, then the horn of the bowl fits into the top and is sealed with a rubber gasket. Thought it would be smaht to replace that rubber gasket but no, apparently it, and indeed the entire assembly, are now unobtainable. Fingers crossed.
Hall Bath Time Machine Overhaul Questions Jnewb74 Tile Forum/Advice Board 39 02-17-2021 09:57 PM
Rob's Master Bath Overhaul saebeil Tile Forum/Advice Board 4 01-27-2016 12:55 PM
Ed's Half-Bath Overhaul coldsolderjoint Tile Forum/Advice Board 9 03-24-2013 05:49 AM
About to get into a master bath overhaul... btlazenby Tile Forum/Advice Board 10 11-21-2012 01:21 PM
Master Bath Overhaul vanwassup Tile Forum/Advice Board 110 12-03-2008 09:57 AM
