Unread 03-06-2007, 12:40 AM   #1
Sah
Walk-in shower, bathroom floor questions, first project
Walk-in Shower
It started off as a simple remove the caulk and bleach the grout and re caulk. The grout was cracked all the way around the base so I decided to remove it and re grout. Well after a few tiles on the curb fell off and the drywall underneath was soaked. I felt it was necessary to do it right.
The house is 12 years old and we just moved in about 3 months ago. The plan for the masterbath is to redo the shower and while I am it, tile the floor. I removed everything that was once the shower. Mortar bed, membrane, plywood subfloor in shower that was scored and screwed down to create slope, drywall that was wet for the bottom 4-6 inches, curb....
The shower is 42" wide and 36" deep, walls on three sides with a glass door. I am using the Schluter shower kit for the entire shower install and using Fiberock in place of the old drywall that the builder used. I have access to the plumbing underneath as there is an interior crawlspace. I feel I have a pretty good hand on the shower or at least for now as I am in a holding pattern. Couple things though. Is it ok to crawl around and stand on the Kerdi membrane to tile the walls or should I put something down? cardboard...
Should I tile the shower floor first?
The bathroom floor was lino which has all been removed. There is 5/8" plywood flooring down, joists are 16" o/c, and a 3/8" subfloor on top of that(with lots of old glue on it). I have screwed the floor all over with floor screws and hit the joist on all. One person mentioned to add another 3/8" fir subfloor but when I got reading about Ditra it didn't seem necessary. Is this necessary?
I am waiting for the heating roll from 'Warmly Yours' to arrive. My main questions are regarding this.
Through reading all the advice on here I plan on putting the heating mat down next, then the Ditra, then tile. I keep hearing about SLC (self leveling compound) and having to use this. Is this necessary? The floor I am dealing with is 75 sq ft and the heating mat will cover 51.
What is the best way to level the floor once the mat is down? SLC?
The current plan is to use tiles 17.5x17.5 throughout the floor and shower. Are the Schluter movement and control joint profiles for where the wall meets the floor and the walls meet in the shower worth it? I also plan to use tile as a base board around bathroom floor. Approx 4" high. Would they be a good idea there? Either between the floor and baseboard or even the top of the baseboard to have a clean finish?
As I mentioned, I am waiting for the heating mat to come in so everything is on hold until then.
Any advice is greatly appreciated.
DIYer
Stacey
Sah is offline   Reply With Quote
Unread 03-06-2007, 12:40 PM   #2
sandbagger
sandbagger's Avatar
Welcome, Stacey!
sounds like we had the same shower builder. I'll take a shot at a couple of your questions.
good move going with Kerdi. Do you have the CBU up already? I know you're prolly gun shy about drywall, but it really does work behind Kerdi - and a lot easier to work with.
best not to walk around too much on the Kerdi. Scrap drywall works great, or heavy cardboard will do.
most folks like to tile the walls first with the logic being that you don't want pookey dropping down on the new floor. It's really personal preference.
I'll leave the floor to others.
-art-
__________________________
Patrick Henry
Unread 03-06-2007, 01:00 PM   #3
flatfloor
"da Leveler"
flatfloor's Avatar
Hi Stcy,
The SLC is not necessary it is an alternative method to placing the mat with thinset. If your floor is not flat you can flatten it and install the mat in one step using the SLC. With 17.5" tiles you really want flat. Emphasis on flat, to quote CX, tile wants flat don't care about level.
Jim Buckley
Tile Calculator
New Here? Read this!
Unread 03-06-2007, 03:08 PM   #4
Sah
thanks so far, couple more though.
I have the fiberock up already and it was very easy to work with, just a little heavier than drywall.
The SLC part.
Would it be best to lay the mat (warmly yours) down and staple to the floor and then simply pour the SLC over and around it? I take it the SLC is very thin and will be able to run through the mesh of the mat and fill all the voids? I read somewhere on here that you need a gap between the walls and the SLC. Is this true? And how thin or thick does the SLC layer have to be? Just enough to cover the mat and wires? Which would be approx 1/8"
thanks again
Stacey
Unread 03-06-2007, 07:42 PM   #5
flatfloor
"da Leveler"
flatfloor's Avatar
Tracy, please take a look in the Liberry, we have a section on SLC and radiant. By the time you get the mat, plastic mesh and SLC down the floor elevation will be approximately 3/8" higher.
Is your floor flat? Best way is to take a straight edge and go around the floor with it.
Jim Buckley
Tile Calculator
Unread 03-07-2007, 03:51 PM   #6
Sah
thanks Jim
I read your SLC part in the Liberry and you mentioned about removing all adhesives from the substrate. There was lino down before and the entire floor is covered with the old glue. Any tips for removing this prior to priming? I have tried in spots to scrape it off but that doesn't work very well. Does it have to come off?
You mention a plastic lathe over any type of wood floor. Is this for strength of the SLC? Would the fibreglass open weave mesh of the heating mat work for this. I will be stapling the heating mat down and the actual wire will be under the mat.
As for, is my floor flat? I uses a string line and can see a couple small dips, probably 1/8" at worst and fairly small areas. Thoughts?
Still waiting on the radiant heating so now is the time to get everything sorted out on what I need to do and don't need to do.
thanks again
Stacey
Unread 03-07-2007, 04:23 PM   #7
flatfloor
"da Leveler"
flatfloor's Avatar
Stacy, what color is the glue? Try wetting it, let the water sit, see if it softens, and then scraping it with a razor scraper on a pole.
We would still like to see you go over the floor with a straight edge.
Jim Buckley
Tile Calculator
Unread 03-11-2007, 12:59 PM   #8
Sah
The glue is a grey and white color I guess. You can't even see the wood throughout the bathroom. I have attached two pics of the floor.
I did go in with a straight edge. There are a couple areas when using the straight edge that are approximately 1/8" lower in spots. Is this a problem?
I also tried the water sitting on the glue and then scraping. It helps a little however I don't think I will ever see the color of the wood underneath the glue. Any other methods that may work better?
Will the glue pose a huge problem for the SLC?
Because of this, would it be better to use thinset over the heating mat and areas that are not being covered by the mat?
Still using Ditra over the mat and under the tile.
Still planning on using 18" porcelain tiles.
thanks again
Stacey
Unread 03-11-2007, 03:48 PM   #9
flatfloor
"da Leveler"
flatfloor's Avatar
The glue is definitely a problem for a SLC. Perhaps someone else will advise on a thinset compatible with the glue.
BTW, have you run your structural data through the Deflecto?
Jim Buckley
Tile Calculator
Unread 03-11-2007, 03:57 PM   #10
Rd Tile
Tile Man
I use Flexbond from HD all the time over cutback adhesive, not sure what you have there, I would've removed the 3/8 ply in question and then added new 1/2" ply., guess you can still throw down another layer of ply if you have the height, not crazy about 3/8" ply in any of my subfloors.
Unread 03-11-2007, 04:37 PM   #11
Sah
I have ran it through Deflecto and came up with this reading. L / 458. Which is ok for tile.
Now I am really confused as what to do.
I don't really have the height to add another layer to the subfloor. You think I should rip out the 3/8" and replace with it with 1/2"? I don't want to get into why but that is a major issue on a number of points for me.
The simple plan to lay the radiant heating, thinset over this enough to cover the wires and mesh (1/8"), and then a similar amount where the mat is not, then lay the Ditra, tile etc..
Not a good idea? Trust me, I do want to do this the right way.
thanks again
Stacey
Unread 03-11-2007, 05:25 PM   #12
Hi Stacey,
You can give the glue the water test. Wet a small area and let it stand for half an hour or so. If the glue dissolves, remove it completely with water. If it does not, you can go over it with the type of thinset that RD tile recommends. I would imbed the heat mat in thin set and smooth it out over the wires. Then install the Ditra with thin set and finally the tiles. Large tiles can be leveled up somewhat with thin set.
Unread 03-12-2007, 06:30 PM   #13
Sah
Getting ahead of myself a little as I am STILL waiting for the heating mat.
Just purchased some rectified 18" x 18" porcelain tiles (R.A.K. Ceramics Gems collection). They have a polished finish. The guy at the tile store said with this type of tile to have a very small grout line. He used a Dime to show the spacing. Is this correct?
He mentioned to use an unsanded grout for this application. By reading other forums this is correct for the size. Are there any specific brands to go with or to steer clear of for unsanded grouts?
The color of the tile is dark charcoal. Any thoughts on color of grout? Black grout? A similar charcoal however it is lighter about the same amount the black is darker.
Stacey
Unread 03-14-2007, 08:29 PM   #14
Sah
Quick Grout Question
bump
st
Unread 03-14-2007, 09:13 PM   #15
Whatever color you like, Stacy. Can't see it from my house.
Not bein' tacky, just making the point that it's a purely aesthetic choice, eh?
You get the glue off the subfloor?
