Unread 09-14-2020, 03:17 PM   #1
atljar
Ditra Heat in Kerdi Board
Is it advisable, or maybe not, to lay Ditra Heat cable in a routered groove in Kerdi board? I know this method is used to go over shower curbs to get the ditra heat into a shower stall, but never seen it used more widely.
Reason: I want to use a kerdi shower pan with a very small mosaic tile, which would eliminate Ditra heat mat from being used due to the small tile size.
Also having some thoughts of using on a small area of the shower wall, directly behind the shower bench. I know schlueter says no to in wall installations, but only because of possible piercing from picture hanging. Dont see that happening in the shower stall. Of course both instances would be covered and sealed with Kerdi band after putting it into place.
Thanks in advance!
Jared
atljar is offline   Reply With Quote
Unread 09-14-2020, 05:18 PM   #2
Not a good idea, IMHO! The surface layer on KerdiBoard helps to stabilize it and routing a bunch of slots in it won't help. That would also destabilize it enough where smaller tile may not be a good choice, either.
I'd call Schluter. Maybe I'm missing something
Unread 09-15-2020, 06:56 AM   #3
atljar
I assumed (dangerous i know!) that the cuts were no big deal as Schluter sells the curved board anyways, that is pre-cut and scored to allow bending and curvature.
Jared
Unread 09-15-2020, 11:41 AM   #4
Assumptions can be dangerous. It might work, but it might not. As I said, your best bet is to ask the company. A significant amount of the surface strength is the continuous surface bonding layer. Routing slots, pushing in a heating wire may not provide the stability you really want and need.
Unread 09-16-2020, 03:29 PM   #5
atljar
Schluter reply for future searches:
NO we would not recommend doing that at all. We do have a recommendation for installing tile that is smaller than 2"x2" over this application.
2"x 2" or smaller tile can not be warranted on our Ditra products. This is specifically due to human installation error and point load distribution.
To further explain it; say for instance that when setting the tile the installer doesn't fill the Ditra waffles or voids fully. Walking along comes someone with high heels or a cane. The tile has the potential to break loose and fall into this void.
In the past (and now) we have recommended that the installer give a skimcoat or prefill the Ditra with a modified thinset or floor leveler, giving extra attention that a flat, solid, smooth bonding surface will work for a base to set the tile. LET THIS SKIMCOAT CURE.
Once this has cured one install tile with an unmodified thinset.
This is ideal for a shower application as the Ditra heat needs to be skimcoated anyway to install the top layer of KERDI membrane
Jared
Unread 09-19-2020, 01:51 PM   #6
Tiger Mountain Tile Inc
Thanks for following up with this.
James Upton
Why you should NOT buy a newly remodeled home ~DIYTileGuy
Ditra XL next to Ditra Heat Duo? Matching thickness? jameshowison Tile Forum/Advice Board 2 03-23-2020 01:22 PM
Mixing Ditra Heat & Strata Heat components jutsin Tile Forum/Advice Board 5 01-10-2019 10:19 PM
Ditra Heat Comments in Regards to Floor Heat matthewstephanie Tile Forum/Advice Board 9 03-17-2016 07:37 PM
Kerdi board under radiant floor heat? doctor_evil Tile Forum/Advice Board 3 05-27-2012 04:24 PM
Kerdi/Ditra and heat mat mcfish Tile Forum/Advice Board 6 03-20-2008 09:39 AM
