Unread 08-05-2020, 01:16 PM   #31
You could cut the bubble out and put on a patch as long as you had at least 2" overlap. You could probably slit it, put some Kerdifix underneath, and not put a patch over it. A quick call to Schluter would give you their recommendations.
Unread 08-06-2020, 10:51 PM   #32
maxwell_smart007
Schluter rep said it's probably fine, but I can cut and patch with thinset and a 2" overlap if I'm concerned...
Andrew
maxwell_smart007 is offline   Reply With Quote
Unread 08-17-2020, 01:14 PM   #33
maxwell_smart007
Fixed, and I'm happy I did it.
Just laying out the tile, and I can't decide how precise to be around the kerdi drain. Do I want a dead-on perfect cut with no wiggle room at all (the way I have it now), or should I shave off a bit of room and surround the chrome drain with 1/8" of grout?
Andrew
Unread 08-17-2020, 01:32 PM   #34
Pretty sure you're gunna want that grout joint between the tile and the drain, Andrew.
Unread 08-17-2020, 01:55 PM   #35
maxwell_smart007
Thanks Dan - I'll look into fixing that tomorrow
Andrew
Unread 08-30-2020, 01:52 PM   #36
maxwell_smart007
Shower floor in and looks good...I'll grout it after I do the walls.
Having some trouble with the shower niches. In my efforts to ensure that they were fully wrapped and waterproofed, I ended up with some out-of-square issues.
I'm going to be using a pencil tile to cover the cut edges and butt the wall tile up to that, but I'm wondering about how to make things look good given the unevenness.
Can I use a medium -bed mortar and use that to essentially shim out the tiles so that they're level/true? In one spot it's about a 1/2" or a shade more...Is that a bad idea in a niche?
Andrew
Unread 08-30-2020, 02:05 PM   #37
You don't want to use mortar like that to build up the tile. Can you post a picture of what you have? What caused the sides to be out of square?
Unread 09-23-2020, 05:23 PM   #38
maxwell_smart007
redid the niches, and they're waterproofed, cured, and tiled.
Trying to get some pencil tile trim around the outside - marble pencil, quite 'chippy' in the saw....
Do I want to cut the mitre so that they fit together perfectly, like a framed window or picture frame, or do I want to leave a thin space that I can later fill with grout?
I'm thinking grout, so I'm thinking I shouldn't fit them so they're exactly fitted - just matched angles with small grout line. Thoughts?
Andrew
Unread 09-23-2020, 08:47 PM   #39
Andrew, you just hafta evaluate your particular situation and do what looks best to you and doesn't dramatically violate any industry guidelines.
I've done mitered stone pencil trim both ways. While the industry requires a minimum 1/16ths" grout joint no mater what, when I have short sections, such as bordering a shower niche, and I like the look of tight joints and my stone is cutting cleanly enough, I'm inclined to fit my joints tightly because I'm a trim man at heart and I don't envision enough movement in those short sections to be a problem. Thus far that's always been the case.
I don't believe even the dreaded Tile Ranger would give me grief on that.
Unread 09-27-2020, 02:10 PM   #40
maxwell_smart007
Thanks CX!
I'm going to change my plan, though. The tile is chipping like crazy on the mitre cut, too, so a butt joint with grout spacing looks better (cleaner cut on the straight cut).
Wife said butt joint, so butt joint it is! (plus this tile is bloody hard to get, and I don't have enough to spare if the saw cuts a chip in another mitre)
Andrew
Unread 09-27-2020, 03:46 PM   #41
Not sure just what you're telling us there, Andrew. You could have either type of joint either with or without a grout gap between the pieces. Using some styles of stone trims I have also occasionally done coped joints. That can also be done with or without grout joints.
When you hear folks talk about using butt joints in stone or ceramic tiles, they're most commonly talking about butting the tiles hard against one another with no grout joint at all. That is specifically cautioned against in the ceramic tile industry.
Therefore I'm declaring myself as officially confused about what you mean in your last post.
You might also look into using a different blade or a different saw to do those miter cuts to see if you can't reduce the chipping.
Unread 09-27-2020, 10:18 PM   #42
maxwell_smart007
I mean that she wants the cuts to be square, rather than mitred...
It'll be much easier, and I won't have to worry as much about chipping buggering up the look of the mitres.
I've tried four different blades - I think it's partly the cheap saw, but a straight cut seems to be better at allowing me to support the tile to avoiding chipping.
Tried the rental store - they don't have a decent saw (small town) - so plan C is skip the mitre - which happens to be plan A for my wife - so problem solved!
Andrew
A few Kerdi-ish questions grinner Tile Forum/Advice Board 44 08-01-2016 08:54 AM
Kerdi Questions dolphyfan Tile Forum/Advice Board 12 05-28-2011 09:07 AM
Some more kerdi questions shenandoah75 Tile Forum/Advice Board 35 03-15-2010 09:24 AM
Ditra/kerdi questions; Minimum tile size, Kerdi on ceiling, ditra over wood? Delta_V Tile Forum/Advice Board 9 06-27-2006 07:27 PM
Some Kerdi questions kevreh Professionals' Hangout 5 02-24-2004 08:52 AM
