Unread 07-23-2018, 11:31 AM   #1
steviesteve
Good Porcelain Wet Saw Blade Suggestions
I bought the Rubi DU EVO tile saw a few months ago and I first used it last night to do lay down 25 sq ft of 12x12 glazed porcelain tiles in an entry way. The saw works very well and I was surprised at how quiet the motor was when running. My only complaint about the saw is that it chips the edges of the tile. I am assuming that the blade is of low quality since it says that it can cut porcelain tiles. Does anyone have any suggestions about which blades would work well on porcelain tiles? The saw accepts 8" blades with either 5/8" or 1" arbors.
Steve
steviesteve is offline   Reply With Quote
Unread 07-23-2018, 01:46 PM   #2
dskater411
Do you mean chips at the very end of your cut or the entire cut edge is rough/jagged? Others can weigh in but I am assuming both are a result of the type of tile or saw more so than having a low quality blade. I have done a couple of full baths using an $80 work force 7" tile saw with a not so new blade and was able to work around both of these issues quite easily. For a rough edge, 15 seconds with a pumice stone cleans it right up. For a chipped end, I noticed it always chipped the same side so I would make the chip be on my scrap side of the cut then clean the usable piece up. Also you can pre-cut one side of the tile 1" or so before turning it around to finish the cut.
david
dskater411 is offline   Reply With Quote
Unread 07-24-2018, 09:39 AM   #3
rmckee84
rmckee84's Avatar
I'll disagree, a quality blade can make all the difference.
Did you dress the blade? A new blade will have a break in period where it may not cut great. Dressing the blade will expose the diamonds and yield better results. I will say sometimes different blades work better with different tile. I usually carry 5 different blades when I show up to an install.
Ryan McKee
Unread 07-24-2018, 01:34 PM   #4
Tile & Stone Guild
King Of Tile
^^I agree, some tiles are harder than others. Glazes are different so sometimes a continuous rim is needed and sometimes the mesh works better and others need a segmented blade. The harder it is the more prone it is to being a little chippy.
A continuous rim will always be the least aggressive as far as chipping but not everything can be cut with one. It will bind and push the blade and youll end up with a curved cut if its dull or material is too hard. Right tool for the job applies.
Jeff
Unread 07-24-2018, 01:54 PM   #5
steviesteve
David
Most of the cut has chips on the surface. The rest of the cut is clean. I have used Felker blades in the past but I was cutting ceramic tiles. I haven't tried dressing the blade so I'll give that a try. Thanks.
Ryan and Jeff
My first thought was the blade because 1.) it is new and I have no experience on how it cuts this or any other tiles and 2.) the motor runs quietly with no vibration when not cutting tile. I have not dressed the blade and in all honesty, I wasn't aware that this was a practice. I have only done minor tile work in the past and always borrowed tile saws. This is my first saw. What blades do you use? I am about to close on a house and I want to remodel the kitchen and bathrooms with various types of tile. I don't mind buying multiple blades as long as they are of good quality because I am certain that I will use them down the line. However, I do not want to buy some that are sub-par and throw $50-$100 down the toilet. I have been looking at Montolit CPF200 8" Perfetto, RTC 8" Porcelain Razor, and Blade Viper Mesh 8". Any advice on this is much appreciated. Thanks.
Steve
Unread 07-24-2018, 03:00 PM   #6
CaliGrown
CaliGrown's Avatar
The 8” Ridgid Blade from Homer’s makes decent cuts on porcelain. Just dress the blade to breck it in with a brick or chunk of concrete
Christopher Machado
Central Valley, CA 1 (916) 990-1751
- The Brutally Honest Tile Mechanics -
Joseph Peres (7/16/95 - 8/31/19)
CaliGrown is online now   Reply With Quote
Unread 07-25-2018, 11:43 AM   #7
Tile & Stone Guild
King Of Tile
Who is the tile manufacturer?
Blades i have Rubi Viper, Lackamond Beast, Black Widow, MK Hot Dog, Pearl P4, Montolit DNA
Jeff
Unread 07-25-2018, 12:24 PM   #8
steviesteve
Chris,
I'll look into the Rigid blade. I didn't really think of them. Thanks.
Jeff,
It was the Marazzi brand.
Steve
Unread 07-25-2018, 04:36 PM   #9
My last 3 blades have been the Pearl P4.
Unread 07-25-2018, 04:41 PM   #10
Curlyrock
Rubi's are good
Well Rubis are respected fairly well so I will assume the quality of your Porcelain isn't up to par perhaps. It shouldn't chip like that. Not with a Rubi.
Curlyrock
Curlyrock is offline   Reply With Quote
Unread 07-25-2018, 05:42 PM   #11
Tile & Stone Guild
King Of Tile
Some of the Marazzi lines can leaned to the hard side. The Pearl P4 should be easy enough to get if the Rigid doesnt work out for you
Jeff
Unread 09-25-2020, 12:06 PM   #12
Homebrew DIY
I like the snap cutter for these situations.
Ray
Homebrew DIY is offline   Reply With Quote
Good porcelain blade for 4.5 inch angle grinder DannyB Professionals' Hangout 43 10-02-2014 09:33 AM
Need a real good 10in porcelain blade? Ron O Tile Forum/Advice Board 7 04-12-2014 05:49 AM
Porcelain Blade Suggestions Higher Standard Tile Professionals' Hangout 50 04-21-2010 06:27 PM
Recommendation for Good Blade postmansi Tile Forum/Advice Board 11 09-30-2009 07:46 AM
Need Suggestions 4 a good Caulk for Tub ultamte Tile Forum/Advice Board 4 04-06-2006 02:18 PM
