Unread 09-13-2020, 06:55 AM   #1
gombi
Building a Curbless Shower
Good Morning!
My last project would have gone wrong without you guys and here I'm again, hoping for your advise.
I’m building a curbless shower 36x48. I use a Schluter shower tray with center drain. Ditra heat will be installed too.
I want to make a pattern like in the image. I saw that the minimum tile size is 2”x 2” with ditra, but what would be the maximum tile size? Would 8"x8" be too big for the slope of the tray.
gombi is offline   Reply With Quote
Unread 09-13-2020, 07:31 AM   #2
I would generally limit it to a 4" tile, but 2's are better as far as conforming to the pan and slip resistance.
Unread 09-14-2020, 08:36 AM   #3
gombi
Thank you!
Unread 09-16-2020, 09:50 AM   #4
gombi
Curbless glass shower installation
Hi!
This question goes beyond tiling, but I hope you can help...
I will install a 36x48 curbless glass shower (10 mm glass). The glass panels slide into an U profiles on the wall and are attached on 2 places on the floor. They don’t include instructions on how to install directly on tile, only instruction on how to install on a shower base (see image).
I know that I can’t put the glass directly on the ceramic floor. I can get some U profile locally, but I would rather go with something that’s almost not visible. Can I use some kind of rubber between glass and the tile floor? What do you guys use in such a case?
Unread 09-16-2020, 10:02 AM   #5
Mike, it'll help if you'll keep all your project questions on one thread so folks can see what you're working on and what's been previously asked and answered. A moderator can give it a more generic title any time you'd like to suggest one.
Why not?
Could you not install your glass panels onto your floor waterproofing (with appropriate "bumpers" of course) and capture it in the tile installation?
Unread 09-16-2020, 10:43 AM   #6
gombi
Thanks CX!
Why not?
Glass on ceramic tile? I see that breaking the glass one day...
I never thought about that... seems to be a good idea but it won't work in this case. I need to use the fixtures that come with the shower because the glass has two 1/2'' holes for the floor attachment fixture. Height is another issue... the door could be touching the floor if the panels are lower than the tile.
Unread 09-16-2020, 11:48 AM   #7
gombi
Cutting the tiles this way would work too, right?
Unread 09-16-2020, 03:23 PM   #8
Mike....I suppose you could, but what would be the benefit? I would think that you could simply set the tiles to match your drain. What you are proposing is a method for using quite large tile in the shower.......
Unread 09-16-2020, 05:22 PM   #9
gombi
The wife wants a tile that is 8x8. I will use a center drain and I don't see another way to use this tile size and get the right slope on the Schluter tray.
Unread 09-16-2020, 07:32 PM   #10
Your wife recognizes the increased slip/fall hazard associated with larger tiles on a shower floor, Mike?
Unread 09-17-2020, 01:02 PM   #11
gombi
I have a few samples of the tile and it's really not slippery. I don't think that this will be a problem with this tile.
Unread 09-17-2020, 01:09 PM   #12
You evaluate that tile surface with water on it and in your bare feet?
Unread 09-19-2020, 01:57 PM   #13
Yes to post 7. I almost suggested that when I saw this thread first pop up.
James Upton
Building a curbless shower wesanc Tile Forum/Advice Board 22 03-25-2020 04:44 PM
Where to start with building a curbless shower for this space? a_day_with_dave Tile Forum/Advice Board 26 04-12-2019 09:07 PM
curbless shower help Bird gang Tile Forum/Advice Board 3 10-09-2016 12:20 PM
Building a curbless shower with slate. BamBamBumbolo Tile Forum/Advice Board 17 04-23-2011 12:33 PM
curbless shower (or almost curbless) Apt4C Tile Forum/Advice Board 656 03-08-2011 09:58 PM
